best cam for 406 SBC in the mud - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 16th, 2010, 10:31 AM   #1
ssdeuces
ssdeuces's Avatar
Default best cam for 406 SBC in the mud
I'm after serious "GRUNT", 10.5 TO 1, Dart Iron Eagles 72 cc 185 runners, 1.94's, Fast burn chambers, 1 5/8 long tubes,probably 5:13's/40's, 2200 stall/th400/205 for now. I'm sure somebody's running a 406 out there.
Thanks
ssdeuces is offline   Reply With Quote
Old June 16th, 2010, 10:37 AM   #2
ssdeuces
ssdeuces's Avatar
also...whats the trick to keep th400 in the lower gears? manual valve body?
Old June 16th, 2010, 01:04 PM   #3
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Are you looking for a Hydraulic Flat Tappet or Hydraulic Roller and what RPM range are you looking at??
Also what size carb and i would assume dual plane intake cause you want grunt?
Ya the only way to keep a TH400 from shifting is to put a manual valve body in them. They will shift no matter what ya do to them. The TH350 if you put them in any gear other than drive it will stay in that gear.
I also have desktop dyno if you want a round about rating for your engine!
Old June 16th, 2010, 03:26 PM   #4
ssdeuces
ssdeuces's Avatar
Since the engine isn't on my stand yet I don't know even the exact compression. I'm sure a flattappet will be plenty good. And less $$$. I have a ZZ4 roller laying here but seems like the older blocks won't take GM roller lifters...am I wrong? I'm planning a 2200 stall so 2000-5500 in rpm. I have two dual planes...ZZ3 GMPP and a brand new Performer. 650 Holley or Edelbrock 1406, have plenty of q-jets and a Carter AFB. Also have TPI w/computer, harness BUT I didn't think it would support the HP. If it will...I'll run it and pick my cam with it in mind....
Old June 16th, 2010, 03:46 PM   #5
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
This motor is the perfect candidate for propane injection. Yes Hoss I'm trying to convert everyone.
BigBlockBlazer is online now   Reply With Quote
Old June 16th, 2010, 03:47 PM   #6
AFRd_CJ5
AFRd_CJ5's Avatar
The best thing you can do, is call the cam manufacturer of your choice, and get a custom ground cam. Have everything else picked out, then call. A custom ground cam is usually little to no more costly than an off the shelf, but you will be much better off.
AFRd_CJ5 is offline   Reply With Quote
Old June 16th, 2010, 04:03 PM   #7
95geo
newbie
95geo's Avatar
For TH400 information:
The DEFINITIVE TH400 valve body / shift kit thread... - Pirate4x4.Com Bulletin Board
Depending on what you want it to do, you may or may not have to buy a valve body.
Old June 17th, 2010, 11:11 AM   #8
ssdeuces
ssdeuces's Avatar
Originally Posted by 95geo View Post
For TH400 information: The DEFINITIVE TH400 valve body / shift kit thread... - Pirate4x4.Com Bulletin Board
THANX...that is some very good info...now I know what to buy.
Old June 18th, 2010, 12:00 PM   #9
frdboy
frdboy's Avatar
I would do a hyd. roller, may cost a little more up front would would be way worth it. Probably would have to run aftermarket linked lifters. X2 on the custom cam. I like Comps XFI roller lobes but they need good parts.
Old June 18th, 2010, 12:05 PM   #10
frdboy
frdboy's Avatar
Also......if this is a dedicated mud truck your gonna want more stall. I would do a 10" maybe 3800 or so.
Old June 18th, 2010, 01:16 PM   #11
ssdeuces
ssdeuces's Avatar
what will an S10 t/c stall at behind a 406? Wouldn't it be near 3000? I'm waiting on Comp Cams recommendation right now and Hoss is running Decktop Dyno for me too. VERY limited funds on this. I'm trying to use leftovers from other projects on the build.
Thanks!
Old June 20th, 2010, 03:43 AM   #12
AFRd_CJ5
AFRd_CJ5's Avatar
Thanks!
No, I don't know of any factory GM converters that would stall anywhere near 3,000RPM. You'd have to either take a chance at finding a cheap used converter, or get a cheap Summit/etc. and hope they work decent.
Old June 21st, 2010, 05:30 PM   #13
Hoss Blazer
!SPARTY ON!
Thanks!
I'm gonna be buying this torque convertor and trying it. I talked to the tech guy there and he recommened this one for my application. BBC w/ torque ban up to 5,800rpm, TH350/NP205, 4.10 gear ratio.
http://www.accperformance.com/Products/index.html
http://www.summitracing.com/parts/APE-47012/
Old June 22nd, 2010, 05:43 PM   #14
ssdeuces
ssdeuces's Avatar
Well...I have some time before this 406 will be thriving in my mudder...Please let me know how well it works, sounds like it might work for me as well....and THANX for the bump stick help!
Old June 22nd, 2010, 05:58 PM   #15
cj65
cj65's Avatar
IMO i would not use a hyd tappet cam. get either a solid flat tappet or solid rollercam. IF you ever need more rpm you dont have to worry about valve float ,and has way better throttle response. just my.02
Page generated in 0.31086 seconds with 69 queries
