87 Yota truggy - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 17th, 2010, 06:16 PM   #41
generalyota
Ridge Runners Offroad
generalyota's Avatar
my kit was 850 plus shipping to michigan was 58.00. Kit comes with everything youu nneed, and Carey is super cool.
generalyota is offline   Reply With Quote
Old July 18th, 2010, 10:16 PM   #42
Mud'N'Truck
I'll Finsh One, One Day
Mud'N'Truck's Avatar
Cool to see another yota build. Lookin good
Old July 19th, 2010, 07:35 PM   #43
generalyota
I finally got the regulator bracket made and mounted up. lines are connected and the solenoid is wired to a rocker switch. I now have to fill the propane tank, head to the salvage yard and pick up my taurus cooling fan. change some fluids and it should be running like a champ!
Old July 20th, 2010, 08:49 PM   #44
generalyota
made a panel to mount the radio, arb compressor switch, air toggle switch and a winch control panel in the near future. I also installed the arb compressor behind the driver's seat, off of the floor. I am going to wire it up this weekend.
Old July 20th, 2010, 08:51 PM   #45
generalyota
Old July 24th, 2010, 08:15 AM   #46
KennyOffroad
KennyOffroad's Avatar
Looks Good !
Old July 24th, 2010, 11:27 PM   #47
generalyota
I hope to have it running by next weekend so we can wheel @ your place.
Old July 25th, 2010, 07:59 AM   #48
KennyOffroad
Old July 28th, 2010, 08:44 AM   #49
generalyota
Got the last 2 tires mounted last night. It is finally sitting on it's own!!! I put the rear axle back together and ran a new vent for it(the old one was completely clogged).
Old July 28th, 2010, 08:56 AM   #50
KennyOffroad
Nice !
Old July 28th, 2010, 05:05 PM   #51
roll-bar Bob
roll-bar Bob's Avatar
great job it is coming well
FYI
I see frame work in the future for you
Old July 28th, 2010, 07:15 PM   #52
generalyota
well so much for having it running this weekend. After filling the cooling system, I found a crack in the intake manifold and it leaks like crazy. I have another intake though. Now I have to take it off and replace it.
Old July 29th, 2010, 08:56 PM   #53
generalyota
Well I believe I have the leak taken care of. I also am using the viscous belt driven fan and shroud instead of an electric one for now until all the gremlins are dealt with. I am going to fill the propane tank tomorrow and fire it up!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old July 31st, 2010, 08:34 AM   #54
pistol pete
I do vinyl stickers
pistol pete's Avatar
nice work looks awesome
pistol pete is offline   Reply With Quote
Old July 31st, 2010, 02:02 PM   #55
generalyota
Angry
well she's a runner!!!!!! After an ignition coil replacement and a slight timing adjustment she's running better than it ever has!!! While I was driving it a brake line broke. So now more work.
Old July 31st, 2010, 10:09 PM   #56
generalyota
ran it today almost all day and used 1/2 a tank of propane. It stats within 1 second. Idles great at extreme angles, I am sold on propane. I should have done this years ago! Fixed the brake line, and now the rest of the build will continue.
1st on the list is replacing the completely burnt clutch and instaling the dual transfer case. Then build the font axle and then install the winch.
Old July 31st, 2010, 10:18 PM   #57
generalyota
now that I am done sourcing parts here's the complete specs on the truck.
22r propane injected
center force 2 clutch
dual t case from advanced adapters, 2.28 in both cases.
trail gear dirty 30's
arb air locker front 4.10 gears
welded rear 4.10's
35" BFG KM2's
trail ready beadlocks
ARB compressor, air toggle
all pro 4" rear springs
rancho shocks
t max ew 9000 winch
Old August 2nd, 2010, 11:50 AM   #58
generalyota
all primed up and ready for some orange paint.
driver's side.
oh btw the KM2's are amazing!!!!!!!!!!!!!!!!!! flex like crazy and hook up really well! I had them at about 7psi on the trail, until the clutch gave up the ghost. Now to install the center force and doubler!!!!
Old August 13th, 2010, 01:47 PM   #59
generalyota
Here's the Ballistic Fab battery box mounted up. I am running the cables under the cab and through grommets this weekend. After my dislocated thumb heals.
The battery box looks sweet and it pretty heavy duty.
Old August 14th, 2010, 04:44 PM   #60
jandrold
jandrold's Avatar
Default Truggy?
I like yotas, and you are doing a good job cleaning it up and adding some good parts, but It is not a Truggy by just taking off and running it without a bed. I don't see the uggy on your Toyota P/U .
jandrold is offline   Reply With Quote
Page generated in 0.37908 seconds with 83 queries
