ford D44 knuckle info - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 10th, 2010, 11:12 AM   #1
jonzer12
Default ford D44 knuckle info
Want to convert my waggy 44 to 5x5.5
I understand that I can buy some chevy spindles and ford hubs and brakes but I am also told I can just bolt on complete all ford knuckle assemblies using waggy shafts Pretty sure gonig this way will be cheaper.
1: Will this work?
2: Are ford D44 knuckles setup for over the knuckle steering like the waggy
3: Any drawbacks to the ford kuckles brakes, hubs etc.
jonzer12 is offline   Reply With Quote
Old June 10th, 2010, 11:32 AM   #2
PavementPounder
PavementPounder's Avatar
The Jeep/Chevy stub shafts are different than trhe Ford even though they are the same spline count and joint size. Fords only have one snap-ring groove. Jeep/Chevy have two.
Yes, you can swap over the Ford outers. However, fewer Ford knuckles are suitable for flat-top machining. F-250 knuckles are good to go from the factory with only the passenger side needing to be machined, but you cannot put 1/2-ton (5x5.5") parts on them.
Start reading: http://77cj.littlekeylime.com/web_rs44.html
Old June 10th, 2010, 11:40 AM   #3
95geo
newbie
95geo's Avatar
What I did was used chevy flat top knuckles with small bearing spindles and chevy stub shafts and calipers/brackets, then I went to auto zone and got the $40 f-150 hub and rotor combo and put that on the small bearing spindles. It widened the axle 3/4" per side but everything worked out well.
Old June 10th, 2010, 11:59 AM   #4
jonzer12
Its the small bearing spindles that concern me, they are pricey new and from what I understand a bit hard to find, thus why I want to just run all ford stuff. I am not going to go with high steer so I like the over the knuckle setup of the waggy, I just don't know if any 5x5.5 fords were the same.
Old June 10th, 2010, 12:02 PM   #5
shawn
Resident HVAC/R Jambi
shawn's Avatar
x2
That's exactly what what I did.
Old June 10th, 2010, 12:23 PM   #6
brandonjb
YJ enthusiast
brandonjb's Avatar
Send a message via MSN to brandonjb Send a message via Yahoo to brandonjb
Ive got some small bearing spindles for sale.
Axle Part(s): D44 Chevy small bearing spindles + rotors, lockouts and knuckles - Great Lakes 4x4. The largest offroad forum in the Midwest
brandonjb is offline   Reply With Quote
Old June 11th, 2010, 08:55 AM   #7
fsumotorhead
N8KVB
fsumotorhead's Avatar
Chevy small bearing spindles aren't hard to find, any chevy 10 bolt front spindles will work as well
Old June 11th, 2010, 09:26 AM   #8
FORDTOUGH
FORDTOUGH's Avatar
I think the easyest thing to do is just swap ford knuckles out. Ford stubs,knuckles,spindles,caliper bracket,hub and rotor. Im not sure how the waggy steering is but Ford is knuckle over and you can ream them for knuckle under.
Im going 8 lug on my d44 pretty soon I have everything just gotta do it.So if your looking I will have every thing you need if interested PM me. I think the ford brakes may be a little smaller than the chevy stuff but I have no problems stopping my 5000# Bronco.
Good luck
FORDTOUGH is offline   Reply With Quote
Page generated in 0.32326 seconds with 48 queries
