94 K1500 affordable suspension lift options. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 10th, 2010, 11:43 AM   #1
SULLY313
Default 94 K1500 affordable suspension lift options.
The truck I just purchased has a 3" body lift to accommodate 33" tires. I hate the look of the body lift. What are my options for suspension lift that won't break the bank? I don't want to drop $1500-2k on a lift kit.
I understand that cranking the torsion keys are frowned upon but how bad is it really? Could I get enough out of it to clear the tires without effecting the 4wd ?
Rear Blocks? Yes or no?
Rear helper springs maybe?
SULLY313 is offline   Reply With Quote
Old June 10th, 2010, 12:01 PM   #2
sanman
sanman's Avatar
Send manyjeeps a pm he has a lift for your truck it's on a truck right now but the truck has never been on the road and he is parting the truck out.
sanman is offline   Reply With Quote
Old June 10th, 2010, 12:03 PM   #3
Klumpper
Fuck Cancer!
You shouldn't need a body lift to put 33"s on that pickup. My brother's 97 tahoe didn't have any issues (except front mudflaps) with 33"s on it.
Take the body lift out, stay away from blocks by all means necessary. Helper springs or add-a-leaf in the back and if you need to, give the torsion bars a little bit of a turn.
This tahoe has helpers in the back, because EVERY gmt400 suv I have dealt with (and half tons for that matter) sags. I picked up the 3 leaf helpers from JC whitney (2500#?) and put them on. Torsion bars are set at factory height.
Klumpper is offline   Reply With Quote
Old June 10th, 2010, 04:18 PM   #4
SULLY313
"Toomanyjeeps"? Thats all that came up when i searched.
Old June 10th, 2010, 04:22 PM   #5
SULLY313
Thanks.... this sounds like the best/cheapest route.
Old June 13th, 2010, 12:27 PM   #6
Puddy Nugets
Road Rage is FUN!
Puddy Nugets's Avatar
I have airbags in the back of my K1500 and with the torsion bars jacked up I could easily clear 33's. This lift will cost you less than $200 and it looks better then a body lift!
The only problem is the ride is ROUGH! You will have no give in your suspension if you turn the torsion key to far and it is not a fun ride if you go offroad.
Puddy Nugets is offline   Reply With Quote
Old June 13th, 2010, 04:00 PM   #7
sanman
sanman's Avatar
sorry it's manyjeep
Old June 13th, 2010, 04:11 PM   #8
osteologation
Everyday I'm Shufflin'
osteologation's Avatar
i know a buddy used ford f150? torsion keys in his 99 to level his lift out. idk if that would work on yours.
Old June 14th, 2010, 12:13 PM   #9
SULLY313
thats what I hear. Do you think it would be cured with longer shocks? I could see the shock reaching full extension before it dampens rebound sufficiently on big bumps.
Old June 14th, 2010, 07:07 PM   #10
Puddy Nugets
Road Rage is FUN!
That might work. I just lowered mine a little to stop the rough ride. I did get a really squeeky ride for a week or two after lowering it. I figured the squeek came from the shocks being extended for a few years and fixed it with some WD40 and a trip through my favorite mud hole.
I think the rough ride comes from the tension on your torsion bar and not the shock extension. I am sure there is someone on here that knows more about it then I do.
Page generated in 0.48540 seconds with 53 queries
