94 K1500 5.7 Tach signal? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 10th, 2010, 11:39 AM   #1
SULLY313
Default 94 K1500 5.7 Tach signal?
I'm trying to hook up a aftermarket tach that was installed in a truck I just purchased. The wire they tapped into for a tach signal is actually 12v swtiched power.
SULLY313 is offline   Reply With Quote
Old June 10th, 2010, 02:24 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
look at the ignition coil behind the air cleaner. you will see 2 plugs on top of it aside from the actual coil wire. one plug is black and connects to the distributor with a red and white wire. the other plug is gray and has a white and a red wire. hook your tach signal to the white wire on the gray plug.
Old June 10th, 2010, 03:32 PM   #3
jbsjunk
Little Member
jbsjunk's Avatar
+1 There might also be a single wire pigtail on the firewall by the dist that you can hook the tach too. Would be a male spade connector.
Old June 10th, 2010, 04:42 PM   #4
SULLY313
got it guys! Thanks!
Page generated in 0.13974 seconds with 35 queries
