jet boats tech - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 9th, 2010, 11:53 PM   #1
nathanthegreat
not really
nathanthegreat's Avatar
Default jet boats tech
im putting a olds 455 jet boat basket case together with a buddy and we cant figure out where the water discharge goes. it has basset headers which both have water going to them but the main outlet for the t-stat also has a hose coming out of it. does this just get ported out the back of the boat? figured i would ask the great minds of GL4x4, any info would be great!
nathanthegreat is offline   Reply With Quote
Old June 10th, 2010, 10:41 PM   #2
nathanthegreat
not really
ttt
Old June 10th, 2010, 10:48 PM   #3
XXXJ
Desert Rat
XXXJ's Avatar
Have you hooked up the bleed out of the bowl?
The two tops go to your logs, That one odd nipple on the thermostat housing is your water intake from your bowl bleed. I'll post a pic tomorrow to be sure.
XXXJ is online now   Reply With Quote
Old June 12th, 2010, 08:57 AM   #4
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I wish my discharge was only water.
@clarkstoncracker
Old June 12th, 2010, 10:20 AM   #5
nathanthegreat
not really
the two water pump inlets have the jet pump hooked to them. The two bassets headers have lines hooked to them also from ports on left and right of t-stat port(water cooled headers) it dont have the "log" system. the t-stat outlet had this crazy valve on it, we were assuming that was the hot water discharge. but the braided line we have dont reach the back of the boat. is that normaly where you discharge the hot water if it has headers? thanks
ID:	64009   Click image for larger version
ID:	64010   Click image for larger version
Old June 12th, 2010, 12:42 PM   #6
XXXJ
Desert Rat
XXXJ's Avatar
Well, we went two different directions (race vs play), but a lot of theory comes to play. I think you want your pump outlet plumbed into your thermostat housing and the lines from the water pump block off go to your wet exhaust.
The valve is to limit the water coming into the block. Too much = Too cool vs Not enough = Toasted motor$$. I prefer the thermostat option.
That 3/4 line off the bowl should be going into the intake. Also when you start it make sure you use that line to feed the block and bowl to prevent wear ring damage.
Old June 12th, 2010, 03:19 PM   #7
XXXJ
Desert Rat
XXXJ's Avatar
Old June 12th, 2010, 10:51 PM   #8
nathanthegreat
not really
huh... good to know, i wonder if the other guy had it piped wrong before i figured there should be hot water coming out of the t- stat. maybe its a jet boat thing...
Old June 13th, 2010, 09:07 AM   #9
XXXJ
Desert Rat
XXXJ's Avatar
Can you post up pics of the boat?
Old June 16th, 2010, 05:52 AM   #10
nathanthegreat
not really
Default pics
just started it up last night for the first time. sounds pretty sweet. hope to test and tune in a couple weeks
ID:	64186   Click image for larger version
ID:	64187   Click image for larger version
Old June 16th, 2010, 06:33 AM   #11
Midnight Rider
Look around here http://www.screamandfly.com/forumdis...s-and-V-Drives the hose layout has been discussed for your motor.
Midnight Rider is offline   Reply With Quote
Old June 16th, 2010, 08:52 AM   #12
XXXJ
Desert Rat
XXXJ's Avatar
Is that a Hondo?
Old June 27th, 2010, 10:20 AM   #13
nathanthegreat
not really
its a "Glenco" i guess a guy named Glen in Ca. made them for a little while. pretty deep hull for a jet boat i've heard.
Page generated in 0.27413 seconds with 63 queries
