what would be a good first welder? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 9th, 2010, 12:55 AM   #1
Ryms88
Ryms88's Avatar
Default what would be a good first welder?
i want to get my first welder for making small brackets, bumpers, etc. i dont know what i should get... any recommendations? preferably looking for something cheap too
Ryms88 is offline   Reply With Quote
Old June 9th, 2010, 01:00 AM   #2
kj kyle
kj kyle's Avatar
definately a MIG. do you have access to 220v? a 120v will work up to about 3/16" (fine for bumpers, and some brackets) then I would say just stick to name brand.
kj kyle is offline   Reply With Quote
Old June 9th, 2010, 01:19 AM   #3
bajatoy53
Raisin
bajatoy53's Avatar
If you want to get started cheap harbor Freight has decent mig welders cheap. Get the replacement warrenty and don't expect it to last more than 2 years with a moderate amount of projects. You can't get parts to fix them easy either. I bought a miller after my harbor freight welder crapped out and love it. Hobart make good welders at a reasonable price too.
bajatoy53 is offline   Reply With Quote
Old June 9th, 2010, 07:32 AM   #4
aber61
aber61's Avatar
millermatic 211 mvp, its about a grand but you will not regret it
aber61 is offline   Reply With Quote
Old June 9th, 2010, 07:37 AM   #5
jonzer12
at a minimum get a 220v 180amp MIG. That is enough machine for pretty much any
hobbiest and a MIG is easy to get started with and very flexible.
jonzer12 is offline   Reply With Quote
Old June 9th, 2010, 07:48 AM   #6
mxracer763
mxracer763's Avatar
I have done quite a bit with a Hobart Handler 140. They run around 500 or 600 new. Great welder for the price and it hasn't let me down yet.
mxracer763 is offline   Reply With Quote
Old June 9th, 2010, 08:38 AM   #7
knaffie
knaffie's Avatar
220V MIG - 170/175/180 series welder at a minimum.
Old June 9th, 2010, 10:12 AM   #8
tom77cj5
tom77cj5's Avatar
the biggest one you can afford. 220 preferably, just remember you will want to weld thicker material than you think and having the bigger welders will allow you to do so
Old June 9th, 2010, 10:31 AM   #9
Quiefinator
go'til itsounds expensive
Since nobody has mentioned this i figured i would, Watch for duty cyles, they should come in percentages. I was under the understanding that the % is based on a 10 minute span @ that amperage.
I.E. a duty cycle of 40%@90amps, can only be run for 4 minutes @90 amps, with a 6 minute waiting period.
Someone please correct or adjust this if its wrong.
Old June 9th, 2010, 10:45 AM   #10
catmando
catmando's Avatar
I have a Hobart that I bought from TSC. I works great, and if you need any replacement parts you can get them from Miller sense Miller makes them. The handle on mine even says Miller right on it.
catmando is offline   Reply With Quote
Old June 9th, 2010, 11:02 AM   #11
fsumotorhead
N8KVB
fsumotorhead's Avatar
I have a 220V Hobart Handler 180 or 185, can't remember, but i love it.
Duty cycle should definatly be considered for whatever you choose to do, with mine the duty cycle drops way off on the higher settings.
Old June 9th, 2010, 11:10 AM   #12
FORD FLARESIDE
Year 2 Griffins Travel
FORD FLARESIDE's Avatar
I'm old school, and an ,..........I bought a Century 85 mig, about 23 years ago for the thin stuff, and I have about a 40 year old Lincoln AC Buzz Box for the thick. I even have the conversion for the mig to weld aluminum, and I do a lot of boat repair in the spring with it.
They seem to work fine for me.
Old June 9th, 2010, 02:57 PM   #13
Ryms88
Ryms88's Avatar
Thanks for all the input i need to make sure i have access to 220v.....and i will ask more questions when they come up... but now i have a start
Old June 9th, 2010, 03:19 PM   #14
ssdeuces
ssdeuces's Avatar
Save your money til you have $600. then buy the Hobart Handler 185 it's 230v but you have 230 somewhere! ....later buy a tank of C02...weld all the steel you can get your hands on...VERY good unit for the $$$...
ssdeuces is offline   Reply With Quote
Old June 29th, 2010, 10:02 AM   #15
the idiot magnet
Keep checking craigslist and similar sites. I picked up a Lincoln 175 SP 220V for $200 not that long ago and a lincoln pro 100 for $40 that I can take with me if I have to. I still have my Craftsman 110V mig welder that I bought several years ago and is a great first time welder.
If we were closer we could work out a good deal on the Craftsman.
the idiot magnet is offline   Reply With Quote
Old June 29th, 2010, 01:46 PM   #16
go1lum
You are correct. In Europe it is out of 5 mins.
go1lum is offline   Reply With Quote
Old June 30th, 2010, 09:51 PM   #17
OldSlowReliable
extra on the SLOW
OldSlowReliable's Avatar
I 2nd the HF welder.....
You don't know if you will enjoy welding or if you are any good at it, and whats the point in spending 600+ on a nice welder if you refuse to use it?
Idk what you're planning on doing, but my 90 amp flux core MIG from HF (they offer a 220v gas MIG I believe) has built me a bumper, and sliders ( I'm having Tab weld my structural supports for the bumper tomorrow to be safe) as well as patched a body panel and welded patches on my frame where it rusted out...
Its easy to use, and I can honestly say I can lay a much better bead than before, and I'm glad I got the welder. With a little prep it can do 3/16" just fine, I wouldn't really go much higher if its a really cruical part though.
The best part is, they are almost always on sale for 70-90 bucks, and alot of the stuff you buy can be used on a bigger machine. A nice auto-dark helmet, gloves, blanket, brushes...
I'd buy a HF cheapo welder, see how it goes for a few weeks/months (I'd say 4 lbs of wire is a good test period) and then decide if you're ready to move up to a bigger nice gas machine..
Or. you can buy a 600 dollar machine, find out you're not the welder you were expecting to be, and sell it to me for $100 :D
OldSlowReliable is offline   Reply With Quote
Old June 30th, 2010, 10:21 PM   #18
Tizken
The first welder I had was the little 5'5" Mexican dude, he could kick ass. Weld upside down and all of it.
Best welding machine was a miller 212.
Tizken is offline   Reply With Quote
Old September 12th, 2010, 08:31 PM   #19
dougstephvoor
Supreme Chancelor!
dougstephvoor's Avatar
I have a miller EZ set 140, it runs off of 110 V. It will do 3/16" real nice, I have welded some 1/2" steel with it by grinding an angle on the butts and pre heating with a toarch, and multiple passes. Small wire machines are not great at any thing over 3/16 or 1/4" but you can do it with proper prep.
Stay away from flux core or coated wire, a gas shield with 25/75 is much nicer and makes a better weld.
dougstephvoor is offline   Reply With Quote
Old September 24th, 2010, 09:59 PM   #20
littletrucker
I'd hit that
littletrucker's Avatar
i have an hobart handler 125- setup with flux core works great- very portable- welded tons and tons of stuff with this guy...
have used a handler 135 setup with gas- works great, probably a little better and slightly cleaner welds
both are great 110 volt welders
Page generated in 0.33731 seconds with 83 queries
