Powerstroke EGT's - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 4th, 2010, 06:34 PM   #1
Default Powerstroke EGT's
So I just installed a pyro on my 97 Powerstroke.
So what are normal egt's readings for dd'ing, towing, cruising etc....
And if I get to hot what should I do to cool it down etc.....
Old June 4th, 2010, 06:43 PM   #2
special k
special k's Avatar
water methanol
Old June 5th, 2010, 07:16 AM   #3
whyme86
whyme86's Avatar
depends anything done to it under load 800 to 1000 stock if modified any more fuel to her gauge 1100 or higher dont let it get above 1100 if it does like special said water injection will help alot
whyme86 is offline   Reply With Quote
Old June 15th, 2010, 11:10 AM   #4
TurdBronco
depends on where the guage probe is installed. Manifold or post turbo?
Old June 15th, 2010, 11:23 AM   #5
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
x37374
Before considering any #'s tell us a little more about what you have, is it stock?
Melting point of Al = 1220 degrees. It is alright (pre-turbo) to get to 1250 for a few seconds, but then you need to back off and keep it below 1100.
RIP FULLSIZE4LIFE
SHARPMACHINE is online now   Reply With Quote
Old June 15th, 2010, 12:55 PM   #6
Stock truck other then cat and muffler delete, soon to have a 3" downpipe and 4" exhaust however. Probe is in the left manifold just before the connector to the pipe.
I did just do a cold air intake a couple days ago but haven't noticed a difference.
I have been seeing 600-800 cruising unloaded, passing somebody or getting on it up hill with no load have seen 1050-1100.
Haven't towed with it yet since the egt install, next weekend will be first trip. I have since installed a boost gauge. Cruising it makes maybe 1-3 psi, jumping on the throttle I have seen a max of 16 psi.
Truck is a 97 powerstroke with 230K with an auto, just installed the SOnnax spring kit and valve in the valve body.
Old June 15th, 2010, 01:13 PM   #7
SHARPMACHINE
F-U-CANCER!!!
Sounds good. Just don't keep it over 1100 sustained. 1250 is ok for a short burst.
RIP FULLSIZE4LIFE
Old June 15th, 2010, 01:17 PM   #8
Thanks, that's about what/where I have been researching as to the numbers to watch for.
Old June 21st, 2010, 09:22 PM   #9
Well I now have a 3" down pipe, 4" straight back to the axle, then a 4" tailpipe up and over.
The DOWN PIPE SUCKED
I also have a leak in the exhaust pipe between the manifolds and the turbo. Once the down pipe was out I could see the black marks around the flange showing the leak. Have to deal with that another day.
Old June 22nd, 2010, 07:21 AM   #10
SHARPMACHINE
F-U-CANCER!!!
Temps should drop. Did your factory down pipe seem/look restrictive?
RIP FULLSIZE4LIFE
Old June 22nd, 2010, 07:29 AM   #11
Other then how flat it was lol, I hadn't noticed, but hadn't paid attention either.
Old October 18th, 2010, 07:52 AM   #12
Tuff_F150
Tuff_F150's Avatar
down pipe on those is a sucky job! did u get yours out in one piece? stocker is way restrictive. ive got a an fpr mod, open air intake 3" down pipe - 5" exhaust. i see 22 psi max
Tuff_F150 is offline   Reply With Quote
Old October 18th, 2010, 10:28 AM   #13
Bones
Bones's Avatar
The OBS downpipe is restrictive. Good move ditching it. The Superduty downpipe isn't as bad considering it is stock.
Do you have a chip?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old October 18th, 2010, 02:07 PM   #14
Me? Nope. Downpipe, 4" straight pipe, cold air intake.
Old October 18th, 2010, 06:57 PM   #15
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
your temps seem kinda high for as stock as it is.
Old October 18th, 2010, 07:35 PM   #16
I can push 1200+ pretty easy towing.
But the shift points of the trans are off and the torque convertor is dieing a slow death.
Old October 18th, 2010, 08:18 PM   #17
Bones
Bones's Avatar
How much boost when your EGTs are at 1200?
You actually want higher boost when your EGTs start to rise. It clears out the heat. Lugging the engine causes higher EGTs.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old October 18th, 2010, 08:22 PM   #18
I see about 20psi max but when around 1200 its typically around 12-14, I have learned to control the egts since the orig post. With the trans teh way it is its a challenge lol.
Old October 18th, 2010, 08:45 PM   #19
Fullsize4life
Kicking Cancers ASS
With temps like that how do guys with tuners keep them low?
Old October 19th, 2010, 05:27 AM   #20
frdboy
frdboy's Avatar
His seems kinda high for being stock tuning. In my 80HP Econo setting I have to push it fairly hard to hit 1200.
Page generated in 0.36717 seconds with 83 queries
