Parting Out 1986 Chevy 1/2 ton - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace > Vehicle Part Outs
Old June 4th, 2010, 11:41 AM   #1
Donti
Stroker
Donti's Avatar
Default Parting Out 1986 Chevy 1/2 ton
Parting out my 1986 chevy 1/2 ton
Built turbo 400 trans with less then 5000 miles with 2500 stall $500
Stock Axels With new Breaks And Bearing's and Seals make offer
We replaced everything in the brake system from the master cylinder back including drums, shoes, hardware, wheel cylinders, pads, rotors, calipers and lines. The rear axle has all new axle seals. All of the u-joints are new, the front axle has all new ball joints, axle seals, bearings, tie rod ends and a steering stab like mentioned before. Everything but the body on this truck is pretty much new.
The Transfer Case is a New process 203 Cast Iron
Make Offer on what u need
pics on other thread
1986 chevy 1/2 4x4 ($1000.00 OBO) new pics added - Great Lakes 4x4. The largest offroad forum in the Midwest
Donti is offline   Reply With Quote
Old June 5th, 2010, 06:57 PM   #2
Donti
Stroker
Donti's Avatar
The NP203 transfer case is a heavy duty gear driven transfer case in a cast iron case. The NP203 gear driven transfer case is considered by many to be the king of bulletproof. It was supplied in many GM, Ford, International and Dodge full-size trucks.
Old June 7th, 2010, 01:50 PM   #3
Donti
Stroker
Donti's Avatar
bump
Old June 18th, 2010, 12:07 PM   #4
Donti
Stroker
Donti's Avatar
bump
Old June 25th, 2010, 11:38 AM   #5
ChevelleSSLS6
For Sale: AMC 360ci v8
ChevelleSSLS6's Avatar
why are you parting it? got pics?
ChevelleSSLS6 is offline   Reply With Quote
Old June 25th, 2010, 03:29 PM   #7
easydoesit
easydoesit's Avatar
Any trades on the trans and t-case. I'll do 150.00 if i pull the trans and t-case and 200.00 if you pull it.
easydoesit is offline   Reply With Quote
Old June 27th, 2010, 04:03 PM   #8
RivMan
You sure it's a 203? I was under the impression that the 203 was the chain driven case, and the 205 was the gear driven case.
If it's a th400 / 205 combo, I may be interested.
Thanks
-Rob
RivMan is offline   Reply With Quote
Old June 28th, 2010, 01:27 PM   #9
Donti
Stroker
Donti's Avatar
lol sorry no the t case is worth 200 alone its a 203 Cast iron Gear to gear there is a huge difference between the 203 and the 205 the 205 is weaker and smaller the 203 is bullet proof but very heavy. mostly wanted for the gear box to make a double low on a 205 witch i think is dum but thats my opinion the tranny is a Turbo 400 rebuilt 3000 miles ago with a shift kit and heavy duty every thing.
if u put it in 1st it wont leave 1st until u shift this tranny is built for 450+ HP
im not taking less then $400.00 on the tranny and $200.00 for the t case or u can buy the whole dam truck for 1g witch every thing is new with life time warrenty except the body.
Old June 29th, 2010, 09:53 AM   #10
RivMan
Asking again about that "Gear driven" 203?? Is it a 205 or a 203??
Your "Bulletproof" comment is used extensively to describe a 205, but never a chain driven 203, Take a look here:
Click to View Search Results for f Google: f
If it is a 205, I'm very interested.
Thanks
-Rob
Old June 29th, 2010, 10:25 AM   #11
BigBert
Gone Huntin'
BigBert's Avatar
203 is cast iron and chain driven... I have one in my barn mated up to a th400. The 205 is gear to gear. Also 203s are full time 4x4 t-cases unless you install a part time kit.
BigBert is offline   Reply With Quote
Old July 3rd, 2010, 08:58 AM   #12
Donti
Stroker
Donti's Avatar
sorry yes i guess it is not gear to gear but it does have the part time kit installed
Old July 3rd, 2010, 09:10 AM   #13
Donti
Stroker
Donti's Avatar
for the right price id sell the truck with the 383 in it i have all the paper work to this motor its a 350 bored .30 with a 400 crank KB pistons Complete Eagle Rotating H beam rods and a Comp Thumpr Cam i know why put a thumpr cam in a truck cause i wanted the thump it makes 365 hp at 5500 Rpm's and about 465 Torque at 5500 running 9.5 to 1 so shes a premium runner or a race fuel its got Dart Iron eagle ss Heads. edelbrock air gap intake. Every thing is externaly balanced id hate to see her go but every thing has her price
Old July 3rd, 2010, 09:10 AM   #14
Donti
Stroker
Donti's Avatar
i wont take less then 2700 for the motor
Old July 6th, 2010, 12:13 AM   #15
Donti
Stroker
Donti's Avatar
Bump Great Deal
Old July 13th, 2010, 12:48 PM   #16
Donti
Stroker
Donti's Avatar
bump
Page generated in 0.34971 seconds with 72 queries
