Nates4x4 Garage Sale - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 3rd, 2010, 03:16 PM   #1
nates4x4
nates4x4's Avatar
Default Nates4x4 Garage Sale
Here are some things I've been wanting to get out of my shop / Best Offer:
Metal sun Approx 12", 1/8 thick steel. $10
5 Gallons Behr Fence and Barn Paint Latex/Oil. Unopened. Paid $80, asking $50
Fluorescent Light Ballast for 4ft fixtures $5
Wagner Paint Sprayer. I should have most of the pieces. Stopped working on me and I never bothered cleaning it. As-IS don't know anything more about it. $10
Brother Fax Machine. Bought used, never tried it out. I have the phone piece but no phone cord. $5
Avery Dwell Angle / Tachometer. Untested. $10
4 U-Bolts and plates. Bolts measure 3 5/8 x 7 1/2 with 9/16 fine thread. $10
3 Sheets 1/8" plexiglass. Replacements for sandblaster I no longer own. 21 1/2 x 10. $5
Water Pump Assembly for Metal Bandsaw. I have 3 of them. $25. Also have a couple gallons of water soluble bandsaw lubricant, $10
4" angle magnets new in box. $5 for the pair
Conduit Bender for 3/4" EMT. Barely used. $20.
8 x 3 3/4 rims, 4 on 4" bolt pattern $10
2 used castor wheels 4.5" - $10
Central Hydraulics Air/Hydraulic 18" Rams. The air pumps were beyond repair and have been plugged. Still work as regular bottle jacks. $40 ea.
Hydraulic Pipe Bender. I suppose if you had enough patience you could make some decent bends. Only tried it once or twice, mostly just used the bottle Jack. $50
Craftsman 6" belt sander. Works fine, bought used and never had a need for it. The stand could use a couple bolts tightened. Someone before me did a half/ass job of adding some shopping cart wheels? $50
Roller Stand for Bandsaw. $5. Water Pump for Bandsaw $25
7 x 12 Bandsaw. Needs work. I have most of the parts. Will need replacement blade guide assembly, possibly some bearings, and one of the wheels wobbles on the gearbox shaft which throws the blades off. $200
Rack roughly 2' x 4' x 4 or 5' tall. Three shelves welded into place. $20
Truck Bedliner. Came out of 1990 GMC Extended Cab Short Box. I also have the tailgate protector. No idea what else this fits, please don't ask I really don't know. Some rust stains, might clean up. $10
CJ-5 Doors. I recommend you have the ability to cut/weld as these need some work. I think I have most of the parts including glass. I don't think I have the window crank knobs. $40
Plastic Chain, 3/8 link, two 25ft pieces. I paid a hundred bucks for this stuff. $25
XJ Roof Rack, all mounting hardware included. Single piece rack measuring 6 x 4. $250
Air/Cut-off Tool with 10 wheels. Did not work as well as I had hoped. but would probably work fine on sheet metal if you're patient. $10
Stainless Steel TIG Rod, 1/8" x 36". About half a box. I don't weld stainless anymore. $20
Chest Freezer, would not fit through my basement door so it has been sitting at my shop since last summer. I paid $75 I'll take $40.
nates4x4 is offline   Reply With Quote
Old June 5th, 2010, 05:46 PM   #2
nates4x4
nates4x4's Avatar
No one wants any of this??
Old June 5th, 2010, 10:27 PM   #3
Ebrown
Ebrown's Avatar
Pm ya
Ebrown is offline   Reply With Quote
Old June 5th, 2010, 10:58 PM   #4
lastmanstandin
EvL 1
lastmanstandin's Avatar
Send a message via Yahoo to lastmanstandin
if you wasnt so far away I would take the bender.
lastmanstandin is offline   Reply With Quote
Old June 19th, 2010, 11:30 PM   #5
VLP
what were those ubolts on?
VLP is offline   Reply With Quote
Old June 20th, 2010, 07:31 AM   #6
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
I don't need it but you might want to put which type of ss fill wire that is. There should be a number such as "316" stamped on the end of the wire. There is different grades of wire for welding different ss applications.
Old November 24th, 2010, 08:01 PM   #7
Jeep ZJ
Jeep ZJ's Avatar
atill have any of this stuff still for sale nate??
Page generated in 0.49689 seconds with 44 queries
