4.0L HO in early Pickup... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 29th, 2010, 11:27 AM   #1
joslovandikai
joslovandikai's Avatar
Default 4.0L HO in early Pickup...
Has anyone ever seen a Jeep 4.0L in an 80's p-up. I realize its sacriledge to the toyota but i killed the 22re in my truck and have a complete 4.0L w/ trans, harness, complete everything already sitting in my garage. So im thinking about dropping the Jeep motor into my 87 pickup. If i were to do it i would eliminate the 4wd(trans is a 2wd one) which i wouldnt mind, as prerunner was always the direction i wanted to go with the truck. Thoughts, comments, etc, welcome
joslovandikai is offline   Reply With Quote
Old May 29th, 2010, 11:45 AM   #2
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
I think the motor is going to be way to long.
Old May 29th, 2010, 12:24 PM   #3
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
yeah you'll probably have to put the radiator in the bed. One plus to a 4.0 over a SBC is that you don't have to worry about clearance for the distributor at the back since it's on the side of a 4.0.
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Old May 29th, 2010, 12:36 PM   #4
joslovandikai
motor will fit w/o cutting if i can run without a fan on the motor and a remotely mounted radiator.
Old May 29th, 2010, 12:42 PM   #5
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
If you remote mount a radiator it would be pointless to put a fan on it.
Old May 29th, 2010, 03:44 PM   #6
robrocketanski
The 4.0 is that much longer than a 7M? Because the 7M fits easy enough. I never thought the 4.0 was that worth while of an engine but it certainly would be different. I mean I have never seen it done (maybe for a reason) but I have seen a 22R in a Jeep :)
robrocketanski is offline   Reply With Quote
Old May 29th, 2010, 03:48 PM   #7
robrocketanski
http://detroit.craigslist.org/okl/pts/1743515843.html
Old May 29th, 2010, 10:48 PM   #8
Yota Bill
lot of work for not much gain...doesnt really seem worth it IMHO...if you want to repower with something different, there are much better options
Old June 21st, 2010, 12:54 PM   #9
elripster
Not-So-Newbie
elripster's Avatar
It should fit. I have seen everything from Frod 5.0's, to Supra 7M's to Benz OM617's in yotas. If that powertrain is just sitting around, throw it in there.
Frank
elripster is offline   Reply With Quote
Old June 24th, 2010, 08:14 AM   #10
Rattler
Home Sweet Homicide
Rattler's Avatar
Frank
I remember a guy years ago (98?) on the Toyota Mailing List through off-road.com that had a 4Runner with a 7M in it.
There is a video on youtube of one with a VW TDI in it that is pretty neat.
Old September 26th, 2010, 09:12 PM   #11
4SquirlAcorn
Destroyer of XJ's
4SquirlAcorn's Avatar
check pirate4x4 a guy did this swap there dont exactly remember the thread name...
4SquirlAcorn is offline   Reply With Quote
Old September 29th, 2010, 04:11 PM   #12
x2.. I think took the whole cherokee front suspension/axle as well...
I would guess its longer than a 5/7m. Those tend to not be the best motors anyway.
Its a lot easier to put a 4.3 vortec in there...
Page generated in 0.26226 seconds with 59 queries
