i have 94 sub what trans is it need help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 29th, 2010, 08:57 AM   #1
6boltfreak
6boltfreak's Avatar
Send a message via Yahoo to 6boltfreak
Default i have 94 sub what trans is it need help
anyone know why when its driving in D it will just switch to N on its own push back to drive and you have no issue untill pops back out. anyone know help me please.
6boltfreak is offline   Reply With Quote
Old May 29th, 2010, 09:01 AM   #2
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
4L60E trans and I would look at the linkage.
Old May 29th, 2010, 09:31 AM   #3
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
what speed? how many miles on the truck? and how much throttle you giving it when it does this?
Old May 29th, 2010, 02:12 PM   #4
6boltfreak
6boltfreak's Avatar
its does at about all speeds. 20 mph to 60 mph it doesnt matter. as far as miles the od says 298k but i dought its the orginal trans and motor. and throttle wise, it doesnt always do it when i amon the gas even and wheni braking and coming to a stop
it will pop out.
Old May 29th, 2010, 02:48 PM   #5
87mopar
Web Wheeler :(
87mopar's Avatar
x2
"Insert Comedic and or ego boosting quote questioning another members sexual orientation here"
http://www.greatlakes4x4.com/imageho...60bd7ea6d9.gif
87mopar is offline   Reply With Quote
Old June 1st, 2010, 01:45 PM   #6
skife
skife's Avatar
how rusty is it? if the body mounts are rusted through its going to put everything on a weird angle and the body is going to move seprate from the truck. it might switch it out of gear.
Old June 1st, 2010, 06:25 PM   #7
6boltfreak
6boltfreak's Avatar
the body is spotless thats why i had bought it. i want to convert it to 4x4 anyone have the parts i need?
Old June 2nd, 2010, 09:43 PM   #8
skife
skife's Avatar
going to need a different trans (or pull the trans and swap the tail shaft) a transfercase, linkage, shifter, probably want to do a solid axle in the front, so that axle is up to you, a SAS kit or some fab work. a steering setup and i think that could be it
Old June 5th, 2010, 12:58 AM   #9
6boltfreak
6boltfreak's Avatar
damn. sounds like inding a 4x4 one witha shot body would be easier.
where at in the linkage am i looking?
Old June 5th, 2010, 01:32 AM   #10
redneck942
redneck942's Avatar
it might be you shift linkage bushing had the same problem myself. if you look around by where the shift linkage rod comes out of the tranny to a arm that pivots you should see some sort of plastic/teflon bushing mine was black but it if you can wiggle or jiggle it at all its probably more or less the bushing
redneck942 is offline   Reply With Quote
Old June 5th, 2010, 01:32 AM   #11
redneck942
redneck942's Avatar
Page generated in 0.27807 seconds with 56 queries
