Basically Free On-Board Air, Think it will work? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 27th, 2010, 12:06 PM   #1
bmx0964
bmx0964's Avatar
Default Basically Free On-Board Air, Think it will work?
So I have been thinking about this for some time now.
I have a 1979 F150 with 6" tube bumpers front and rear and they will hold air. I was thinking about trying to find an A/C compressor for the truck and install it. Then I was going to take the the suction line (low side line) and cut it about 3" from the the compressor and put an air filter from one of my R/C cars over the end of the line (I have one that will fit perfect). Then take the discharge line (high side line) and run it to my front and rear bumpers and use those for air tanks.
What do you guys think? Do you think it will work?
bmx0964 is offline   Reply With Quote
Old May 27th, 2010, 12:13 PM   #2
scare-crow
the eskimo bro
scare-crow's Avatar
Send a message via AIM to scare-crow
it might.... it works with york style compressors and you might wanna use a pressure gauge too
scare-crow is offline   Reply With Quote
Old May 27th, 2010, 12:13 PM   #3
redhead_823
redhead_823's Avatar
Depending on what kind of compressor you get, it may need a lubrication source. You will also need a pressure switch and plumbing stuff, so it will not be free.
Other than that, it sounds like it should work.
redhead_823 is offline   Reply With Quote
Old May 27th, 2010, 12:15 PM   #4
scare-crow
the eskimo bro
scare-crow's Avatar
might not need a pressure switch just mount a pressure gauge in the cab and run a switch to the clutch. once its full turn it off
Old May 27th, 2010, 12:19 PM   #5
bmx0964
bmx0964's Avatar
Well I got a pressure gauge in the garage that I can mount inline in the line and the compressor will be hooked to a switch so I can turn it on and off. Plumbing shouldnt cost me anything since I work as an engineer designing basically all tube and hose assemblies on heavy duty trucks and farm equipment so work will supply that lol.
I guess I should have said basically free for me lol
Old May 27th, 2010, 12:48 PM   #6
redhead_823
That's fine, but you should probably have a blowoff valve in case you forget to turn it off.
Old May 27th, 2010, 12:58 PM   #7
bmx0964
bmx0964's Avatar
Oh yea I will... its called not a super tight belt on the compressor
Old May 27th, 2010, 01:23 PM   #8
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
If your an "engineer" why are you asking if this will work?
Old May 27th, 2010, 01:24 PM   #9
bmx0964
bmx0964's Avatar
Because I design tube and hose assemblies not on-board air systems with a bunch of components that werent designed to what I want to make them to do dick
Old May 27th, 2010, 01:43 PM   #10
BigBlockBlazer
Axle breakin' 101
It was a simple question that was not intended to provocate name calling. On board air utilizing tube bumpers has been around since 1970.
Old May 27th, 2010, 01:59 PM   #11
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
I had a system like that on my old XJ. There's lots of plans on the interwebz that show you the wiring schematics. It's about $30 - $50 for the valves, lines, relays, and other fittings that you need for it to work correctly with a tank.
Now I'd seriously reconsider your thought of using your bumpers as air tanks. I'm pretty sure that it's illegal in most states, but I'm sure that someone on here that's smarter than I am will post a link to the legal mumbo-jumbo pertaining to it.... Just mount an air tank in the side if the rear hatch area and you will be set to go. Don't forget the shut-off valge at the tank for when the compressor shuts off so it doesn't empty on your every time the compressor shuts off.
Old May 27th, 2010, 02:35 PM   #12
bmx0964
bmx0964's Avatar
What does provocate mean?
Old May 27th, 2010, 02:36 PM   #13
bmx0964
bmx0964's Avatar
Well I'm not to worried about the laws because my truck only sees pavement once in a great while... its a wheeler. I mean they would get me for a lot more other stuff before bumper air tanks lol
Old May 27th, 2010, 02:45 PM   #14
BigBlockBlazer
Axle breakin' 101
www.dictionary.com
Main Entry: provocate
Part of Speech: v
Definition: to provoke
Old May 27th, 2010, 02:46 PM   #15
BigBlockBlazer
Axle breakin' 101
I was just randomly busting balls.
Old May 27th, 2010, 02:49 PM   #16
bmx0964
bmx0964's Avatar
You see that is incorrect... you put "to provocate" the definition of provocate is "to provoke" so in essence you just said "to to provoke."
Old May 27th, 2010, 02:53 PM   #17
BigBlockBlazer
Axle breakin' 101
Do you want me to go back through your sentencing structure in this post? And it is not incorrect, you are interpreting it incorrectly.
Old May 27th, 2010, 03:04 PM   #18
bmx0964
bmx0964's Avatar
No it should have been, "was not intended to provoke name calling."
Old May 27th, 2010, 03:10 PM   #19
95geo
newbie
95geo's Avatar
Do you have an engineering degree?
Old May 27th, 2010, 03:20 PM   #20
bmx0964
bmx0964's Avatar
yes i do
Page generated in 0.51841 seconds with 84 queries
