michigan law for securing a vechile on a trailer. - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Land Use > Rules, Regulations, Trail, and ORV Park Chat
Old May 25th, 2010, 10:26 PM   #1
87mopar
Web Wheeler :(
87mopar's Avatar
Default michigan law for securing a vechile on a trailer.
a buddy got a ticket because his backhoe wasnt secured well enough or some bs. he had chains around the axles but the cop said the bucket had to be secured and the hoe had to be secured.. so all for corners and bucket belly plate and hoe? whats this mean for cars 4 straps? could i get away with three? i just would like to see the law i couldnt find it.
"Insert Comedic and or ego boosting quote questioning another members sexual orientation here"
http://www.greatlakes4x4.com/imageho...60bd7ea6d9.gif
87mopar is offline   Reply With Quote
Old May 26th, 2010, 04:47 PM   #2
87mopar
Web Wheeler :(
87mopar's Avatar
no one??
Old May 29th, 2010, 08:14 PM   #3
87mopar
Web Wheeler :(
87mopar's Avatar
can anybody point me where i can find this i looked on michigan law but missed it.
Old May 29th, 2010, 08:33 PM   #4
NSmist
NSmist's Avatar
Send a message via AIM to NSmist
Was just reading up on some towing stuff on Pirate 4x4. You might take a look at this reply:
Pirate4x4.Com Bulletin Board - View Single Post - How to strap rig to trailer?
I've usually seen backhoes tied down with a chain around one of the teeth on the bucket. Probably around the arm too.
NSmist is offline   Reply With Quote
Old May 29th, 2010, 08:46 PM   #5
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
The machine as well as all attachments have to be chained down. 4 Corners of the machine, front bucket with one chain, rear bucket with one chain.
Old May 29th, 2010, 08:47 PM   #6
SammySmalls
SammySmalls's Avatar
I got a ticket for "Unsecured Load" when hauling some wood for deck, even though everything was tied down. The fine was $500, which I think is aimed to hurt commerical loads. I got it reduced... but I think its called "Unsecured Load" and can be at the whim of an officer.
SammySmalls is offline   Reply With Quote
Old May 29th, 2010, 08:51 PM   #7
oz97tj
Wasn't this attached?
oz97tj's Avatar
You don't need any straps or chains as long as somebody rides in the backhoe to hold the brake to make sure it doesn't move.
Also, remember to install your dune flag to the backhoe if planning on transporting it in this manner.
********GLFWDA.org********
Old May 29th, 2010, 09:33 PM   #8
greatpumpkin
Newbie No More
greatpumpkin's Avatar
The reason for the arm and or bucket to be tied down is in theory and in a couple of occasions the arm has risen going down the road and hit overpasses. The MI DOT cops have become real pricks lately. Instead of pulling some one over and explaining this they do it to write tickets. AND if we have any officers purusing this site, don,t get mad at me cause Ive seen it way to often, seeing is I drive Flatbed for a living.
If your really want to know call the state police and ask them
greatpumpkin is offline   Reply With Quote
Old May 29th, 2010, 10:21 PM   #9
babyjp95
average guy
babyjp95's Avatar
i work in an industry where i move a lot of machinery n we have to tie down anything that moves and if it will come off with ease it should b removed. for instance if the back hoe had an interchangeable bucket it should b taken off during transport if the cop felt like being a dick, n our company just got hit with a ticket for not having heavy enough chains on r fork truck even though it weights 15k n we had 2 8800 lbs chains. now we have to use 4 of them chains, so i guess it depends on the cops mood. but I've always tied down the axles on a car, thats my practice.
hope that helps
babyjp95 is offline   Reply With Quote
Old May 30th, 2010, 05:50 PM   #10
oz97tj
oz97tj's Avatar
It's not LEs job to explain laws to you. It's their job to enforce the laws. It's your job to learn the laws before going out.
hope that helps
How do you figure an 8800 lb chain is enough to secure a 15000 lb load? If I'm understanding this right, you had one at front and one at back. Seeing as both chains were securing in different directions, you were severely under limit. I'm not sure if somehow you think both chains added up to 17600 lbs or not, but they wouldn't unless both chains would be pulling the same direction. This is why you need 4 chains (two on front, two on back). If something were to happen that would cause the trailer to slow or speed up quickly (or for that matter change directions) the two chains in your first scenerio wouldn't have a chance and somebody could get hurt. It has nothing to do with the cops mood. You were not secured properly. Not even close. Had something happened, you would have been grossly negligant and would be sued. Your ticket is cheap compared to other options.
Old May 30th, 2010, 06:10 PM   #11
87mopar
Web Wheeler :(
87mopar's Avatar
thanks guys
Old May 30th, 2010, 06:17 PM   #12
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
when i haul cars i use 4 straps to hold it onto the trailer. and i agree with everything about securing a tractor/backhoe. one thing also with construction equipment is you must make sure it does not exceed bridge height. if you have ample room you should extend the boom of a backhoe out flat enough so it's lower then the height of the cab. friend of mine forgot this and took out a low bridge. oops. lol
Old June 3rd, 2010, 06:59 PM   #13
greatpumpkin
Newbie No More
I don't agree... a lot of private folks just doing there own thing, shouldn't get a ticket just because they didn't know. Here lately I've been seeing a lot of that An officer has to know the law to enforce it. So when he pulls someone over he should be able to decipher if they didn't know the laws or not. This philosophy that you have to write a ticket no matter what is ignorant. If s person was truly in wrong then ticket them. If they obviously didn't know ,then don't write it.
Old June 4th, 2010, 09:39 AM   #14
redleg
Anybody remember when 131 at 76th st was shut down most of the summer for structural damgae whne the excavator boom hit the overpass? How about 96 at Alpine when the backhoe arm swung over and hit a wall? I think it was 131 at 54th where a dumb was raised and hit the overpass. Keep taking shortcuts...
redleg is offline   Reply With Quote
Old June 4th, 2010, 02:13 PM   #15
Hauling a backhoe is a commercial issue. It's different than non commercial hauling.
Old June 4th, 2010, 02:20 PM   #16
Flexin' XJ
Flexin' XJ's Avatar
What if it is your own personal backhoe for use around the house? Same as not needing a CDL to drive a semi if your not using it for commercial use. (I think)
Flexin' XJ is offline   Reply With Quote
Old June 4th, 2010, 03:35 PM   #17
That's for you to argue with the weighmaster or cop. Not me. I don't think you'll find very many people hauling around a backhoe that they just use for personal non business use.
My son in law has a CDL, DOT numbers on his truck, etc. He gets stopped on a regular basis and inspected. It's part of the game. If you don't know the rules, tough.
Old June 4th, 2010, 04:08 PM   #18
redleg
Ummm... no, you're gonna want a license. And a loose load is a loose load, you damage part of the roadway, they'll bill you or your insurance. You hurt somebody, you might go away.
Old June 4th, 2010, 05:01 PM   #19
oz97tj
oz97tj's Avatar
What if I didn't know it was illegal to shoot you? Does that make it ok then because I didn't know better? I should just get a warning from the nice officer I suppose.
Old June 4th, 2010, 08:49 PM   #20
You're not a good enough shot.
Page generated in 0.54490 seconds with 84 queries
