mopar 360 in cj5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 25th, 2010, 08:38 AM   #1
shotgun0076
shotgun0076's Avatar
Question mopar 360 in cj5
I just got a mopar 360 to put in my cj5 and I am trying to find out what kind of trans I can use and if I can continue using the same transfer case or have to swap it? I am on a very limited budjet so if you could tell me the cheapest way to make this work I would definitely appreciate it!
shotgun0076 is offline   Reply With Quote
Old May 25th, 2010, 08:39 AM   #2
shotgun0076
The 360 is from the 70's btw
Old May 26th, 2010, 08:22 PM   #3
Westside Willy
Westside Willy's Avatar
You need to PM Plato2k5 - he did a similar swap a couple yrs back. I am sure he help you out.
WW
Westside Willy is offline   Reply With Quote
Old May 29th, 2010, 10:56 AM   #4
shotgun0076
thanks! ill look him up.
Old May 30th, 2010, 08:37 AM   #5
shmler
shmler's Avatar
Send a message via AIM to shmler
I'm in the process of putting that motor into my CJ 7. I am using a 727 auto with the amc tailshaft for the shortest length. I am using a 231 tc with a slip yoke eliminator, but I am drivers drop with my front axle.
I think to make the 360 work in a cj5 you would have to use a manual trans. unless you are stretching the wheel base. But that is just a guess... you can make anything work with some time!
shmler is offline   Reply With Quote
Tags
cj5, mopar 360, trans, transfercase
Page generated in 0.23485 seconds with 38 queries
