2.3 troubles - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 24th, 2010, 03:53 PM   #1
cgarbo
HILLJACK DESIGN'S
cgarbo's Avatar
Default 2.3 troubles
My dd is a 95 ford ranger 2wd 5sp manual trans, the thing is running like shit, idles fine but when put under a load it just baisiclly pukes out, any ideas ive already done the dpfe sensor, new egr valve, new plugs wires im running out of ideas
cgarbo is offline   Reply With Quote
Old May 24th, 2010, 09:01 PM   #2
Yota Bill
how many spark plugs did you replace?
In 1989 the 2.3 was changed to a DIS (Distributorless Ignition System) ignition utilizing a new 8-plug head ( 2-plugs per cylinder). This head had larger evenly spaced D-shaped intake ports and was used until the end of production of the 2.5 in 2001.
Old May 24th, 2010, 09:36 PM   #3
Drg racr
Drg racr's Avatar
Check your timing belt also. I've had quite a few 2.3L Fords jump time on a worn belt. They should be replaced every 75K miles.
Drg racr is offline   Reply With Quote
Old May 27th, 2010, 03:07 AM   #4
Fraser
Fraser's Avatar
. somebody changed 6 out of 8 of the ones in my truck before i got it, still had the intake side back two stock plugs and wires from 97 in it. w/ 186xxx miles.
Page generated in 0.28031 seconds with 35 queries
