Washed motor, fried something! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 19th, 2010, 09:12 PM   #1
rinking
rinking
Default Washed motor, fried something!
Haveing some issues with the 5.7 vortec in my jeep! I washed the mud out from under the hood a couple weekends ago! Drove my rig out to my pole barn and parked it for the week. Went to drive it up town last weekend and when I try to go down the road it spits and sputters. Sitting in neutral, it will rev fine, but when you put it in gear and put a load on it, the sputtering begins! It will start, and idle fine. I just went out and started it and shut the lights off in the shop. I see a little bit of arching on the coil! I'm thinkin i'll start with a new coil! Any other good idea's? It's got new rotor, plugs, wires. the motor came out of a 98 chevy pick-up. Help, please!!!
rinking is offline   Reply With Quote
Old May 19th, 2010, 09:18 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
if you have been in the mud and got it on the plug wires just spray them down with some silicone spray while its turned off. do not do it running. it uses propane and is flammable while in the air. I used to carry a can when snow plowing. once in a great while I would get into light mud and splash it up on my wires. if there any mineral in the dirt like salt or others stuff it will short the wires. dunno why but the spray helps. if it cure yours I suggest a better grade of wires if its a regular to the mud.
Yetti
Old May 19th, 2010, 09:35 PM   #3
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
x2 on the wires being bad.
Old May 19th, 2010, 09:44 PM   #4
rinking
rinking
I dont go purposely mud bogging, but I do charge a few mud puddles from time to time! I got the plug wires at Autozone, I think they are Duralast. Not top of the line, I know! I would'nt think I should be seeing any spark around the coil, witch I am!
Old May 20th, 2010, 07:15 AM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
change that coil wire and see if your problem goes away. either the wire is bad or the coil could be cracked.
Old May 20th, 2010, 08:06 AM   #6
OL RED
workin hard to play hard
OL RED's Avatar
Send a message via Yahoo to OL RED
buy it all new acdelco shit and then listen to it purrrr. i dont know why but mine runs like shit unless its got delcos. just a gm thing i guess
OL RED is offline   Reply With Quote
Old May 20th, 2010, 10:46 AM   #7
IFS SUCKS
I like trees
IFS SUCKS's Avatar
x2
IFS SUCKS is offline   Reply With Quote
Old May 20th, 2010, 07:15 PM   #8
rinking
rinking
Put new coil on it, still runs like shit! I still have My old plug wires, maybe i'll go swap coil wires.
Old May 20th, 2010, 08:46 PM   #9
Yetti
Yetti's Avatar
as an example I once had a battery fall into the fan on my car. it wasn't tied down and the case got a tiny hole in it. I didn't think much of it at the time. by the time I got home the car was running like crap. I thought I had blown a head gasket it ran so bad. I said screw it and tore off the heads and redid both head gaskets in about 7-8 hours with hand tools. by the time I went to restart it. it was now dark out. as I tried to start it the whole top of the distributor lite up with a blue halo. I couldn't get it to run any better then it had before the heads were pulled. I turned it off and sprayed it down the wires with silicone. it took right off and ran. no blue halo. come to find out I had just enough dirt and battery acid to short the whole ignition system out and the wires were like new. I have since saved myself many times over remembering this and it works well. its one the first things I try on stuff that doesn't run right with no solid explanation.
Yetti
Old May 24th, 2010, 08:55 PM   #10
rinking
rinking
Still haveing trouble! Sprayed cap and wires with silicone, no change. Checked spark on all plugs, good. Changed fuel filter. sprayed intake with carb cleaner to check for intake leak, no change in idle speed. swapped maf sensor and tps sensor off my buddys truck, no change. Last time it threw a code, (maf sensor input low), and (#4 cyl. missfire). That was before I swapped out the maf sensor. It's really starten to piss Me off! I just might have to break down and take it to a shop with a computer. It's makeing a weird chirping sound on the front of the motor, can't figure that out either! Sometimes It seems to run ok, other times I have to jack the throttle off to keep it going. Any more idea's! Maybe a bad ground?
Old May 27th, 2010, 11:22 PM   #11
fatty6042
did u take the cap off and see if there is water inside it sounds like there is
fatty6042 is offline   Reply With Quote
Old May 28th, 2010, 09:01 AM   #12
rinking
rinking
No water anywhere! I just dropped it off at a shop with a fancy computer. Hopefully they can tell Me what to fix next.
Old May 28th, 2010, 09:06 AM   #13
fsumotorhead
N8KVB
fsumotorhead's Avatar
x2
Spray down the entire inside of the cap and rotor with WD-40, it should displace any water that may be in there.
Many times you can't see the moisture, but it is there no the less
Old June 2nd, 2010, 03:12 PM   #14
Judo
Science Patrol
Judo's Avatar
Last time I had issue like that it was my O2 sensor. I know that that diagnosis doesn't seem to fit given the wet engine. I would think ignition specifically the cap and rotor. But My old truck has bad O2 and would idle fine but put any load on it and it hogged right down.
X2 on the Delco parts
Please report back what you find....
Judo is offline   Reply With Quote
Old June 5th, 2010, 10:01 AM   #15
skife
skife's Avatar
if its an early vortec it might be the injectors.
Old June 5th, 2010, 10:23 AM   #16
lastmanstandin
EvL 1
lastmanstandin's Avatar
Send a message via Yahoo to lastmanstandin
x2 on the O2 sensor just went through the same shit on my XJ
lastmanstandin is offline   Reply With Quote
Old June 5th, 2010, 10:38 AM   #17
Yetti
Yetti's Avatar
my curiosity is peaked. I will be waiting to hear what they found.
Yetti
Old June 7th, 2010, 06:58 PM   #18
rinking
rinking
Well I found out I have the old problematic injectors! I talked to Jim at Jims performance and told him My issues and he asked what injectors I have. Sounds like I'm going to have to buy the new style! Whats another $320 anyways! Wifes pissed! I'll keep ya all posted.
Old June 14th, 2010, 10:39 PM   #19
rinking
rinking
New injectors, didn't help! Did compression test, 140-145 in all 8. did a fuel pressure test, When I turn the key on to cycle the fuel pump it spikes to 60 psi and then drops to 55 psi. When the motor is running it stays around 51-52 psi! My book says 60-66 psi. Is My pump on its way out?
Old June 14th, 2010, 11:10 PM   #20
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
Is there a relay or fuse link under the hood that could have water in it?
Silver Bullet is offline   Reply With Quote
Page generated in 0.41206 seconds with 83 queries
