95 gmc 2500 EXT cab SAS'd 35's - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 14th, 2010, 08:26 PM   #1
halfgassed
halfgassed's Avatar
Default 95 gmc 2500 EXT cab SAS'd 35's
ONLY SELLING BECAUSE I NEEDED 2 MORE DOORS. My crew cab is here so this is no longer needed.
First off I'd like to mention that EVERYTHING I did on this truck was built to last, be dependable, and cheap/easy to repair for the long run, I didnt plan on selling this anytime in the next 5+ years. Truck has been my daily driver/tow rig.
1995 GMC 2500 ext cab, SLE. 4x4. TBI 350. ac/cruise/tilt/cd/ etc etc etc fully loaded. She say 186,000 on the odometer. Thats were the normal stops
This is everything that has been performed in the last 20,000 miles.
-ORU straight axle conversion kit
-2 1/2" superlift soft rider front spings
-all bilstein 5100? shocks
- COMPLETE Stainless BRAKE AND FUEL LINE kit for the entire truck from inlinetube.com
-PaceSetter direct manifold replacement headers (no paper gasket BS)
- dual 2 1/2" exhaust with 40 series flowmasters
- the 4l60E trans has been rebuilt, and "BUILT" with many upgrades designed for towing/abuse (cost 1400 to have done)
-entire frame has been wire brushed and painted with POR'15
-ORU dropped pitman arm
- cross over steering using 1.5" .25 wall DOM and 1 ton TREs.
Axles
-410 gears
-78ish ford f250 Hi Pinion d44. Only things that were used was gears/carrier/housing/ inner shafts
- chevy dana 44 flat-top knuckles
-WFO "Thick" high-steer arm for the x-over steering
-All chevy 3/4 ton 8 lug outers/ outer shafts
-all new spindle bearings/wheel bearings/balljoints/tie rod/seals/carrier&pinion bearings/rotors/calipers/u-joints
-COMPLETLEY REBUILT
-all steering components are MOOG
Rear is a chevy corp 14 bolt from a 79ish one ton
-410 gears
-Blue torch fab rear disk brakes
-new bearings seals etc
-ALl the rear brake work has less than 2,000 miles on them, including all bearings and seals
no lowballing, iF I dont get what I want Ill keep it and hang a plow on. Its an extremely dependable truck (ive driven it atleast 4 times from the UP to detroit without any second thought even UP to green bay a few times). Truck is currently located in around marquette mi (da UP) but if someone is serious I could aid in delivery.
I'll knock 500 off the price if I can keep the tires, Truck has hte typical gm ext cab rust, needs new cab corners and rockers, the rest of the body is solid.
$4500
Pm me or call me at 906-942-7528.
Last edited by halfgassed; May 14th, 2010 at 08:32 PM. Reason: forgot pics/price/my spelling sucks
halfgassed is offline   Reply With Quote
Old July 2nd, 2010, 03:12 PM   #2
robertfreeze74
trade for a 99 c1500 suburban w/123k miles and 3rd row seating?
robertfreeze74 is offline   Reply With Quote
Old July 14th, 2010, 04:45 PM   #3
wild thang
3/4 ton or heavy half ton set up?
wild thang is offline   Reply With Quote
Old July 14th, 2010, 06:38 PM   #4
xj_man_646
Wheeler-less
xj_man_646's Avatar
Send a message via AIM to xj_man_646
Nice looking truck...I really really really really really really really wish it didn't have cab corner rot...if it weren't rusty I probably would have bought this from you as soon as I saw it for sale.
xj_man_646 is offline   Reply With Quote
Old July 15th, 2010, 05:12 AM   #5
halfgassed
halfgassed's Avatar
truck was originally a 6 lug 2500. BUt has had a 14 bolt ff and an extra leaf added to rear spring packs.
Dependable truck, only 20,000 miles on rebuilt trans/axles/suspension/steering. I've actually be driving it again instead of putting mileage on my new truck, odometer now say 188,000. It actually rides better than my 03 chevy
Motor burns roughly 1 1/2 quarts between oil changes (which it has since I've owned it @120,000) I find that funny because my 03 chevy with 80,000 miles burns 2 quarts
THe inner rockers and floors are still solid, floors still have factory paint on the underside. The reason for the rust was the previous owner had stainless rocker trim on the truck.
If not sold in the next 2 weeks (or before lift goes on my crew cab) the tires are coming off of this and getting replaced with bald 305's, or 285's. I need tires for my new truck bad and was planning on purchasing new after this sold.
I'd be interested in partial trades.....such as early bronco related items, 35-38 tires (swampers/boggers/etc) , 285's for a 16" wheel, High performance Big block chevy parts, 4 speed trans (t-10's, muncie's etc), v plow's, dana 60 stuff etc.
Heres a pic when It was completed 2 years ago....
Old July 15th, 2010, 05:15 AM   #6
halfgassed
halfgassed's Avatar
if someone buys it before I pull the tires 4200 takes it ( i really dont want 315's on my new truck) 3,800 with out.
I put $7000 in parts/supplies in to this truck when I rebuilt it, no expense was spared.
Old July 15th, 2010, 05:33 AM   #7
TanTahoe
TanTahoe's Avatar
Good looking truck. Looks like the solid axle was always there. Good luck.
More info on the crew cab?
TanTahoe is offline   Reply With Quote
Old August 30th, 2010, 11:01 AM   #8
halfgassed
halfgassed's Avatar
*sold*
Page generated in 0.27496 seconds with 47 queries
