dana 60 pinion angle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 10th, 2010, 11:58 PM   #1
s10v8zach
JACK STAND WHEELER
s10v8zach's Avatar
Default dana 60 pinion angle
i have a chevy dana 60 front axle im gunna order degree shims for and i was wounding what the best pinion angle would be? so that there is a good angle for the drive shaft while keeping the caster angle in check. i know there will have to be a little positive caster to get a good drive shaft angle but i can deal with a little "dig steer". thanks in advance for the advice.
s10v8zach is offline   Reply With Quote
Old May 13th, 2010, 05:53 PM   #2
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
I would try to keep the pinion angle low if you can. The working angle on most u-joints is like 10 degrees. Also the more positive castor you have the more it will wander and try to steer itself. If you get into something like a 6 or 8 degree shim you will hate life. Probably the best thing would be to get your pinion angle where you need it, then clock the knuckles.
BAD93SBLZR is offline   Reply With Quote
Old May 13th, 2010, 08:03 PM   #3
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
your better off leaving the angle alone and simply getting a double CV joint driveshaft. I.E a cv at each end. they don't care about angle differences and will last longer then a single cardan joint in a lifted rig anyways.
Page generated in 0.18721 seconds with 32 queries
