Some aluminum welding - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 10th, 2010, 07:51 PM   #1
CreativeFab
used to be Ironman
CreativeFab's Avatar
Default Some aluminum welding
Built some sign posts for Dow Chemical today, blew the dust off the spool gun.
used Harris .030 wire ran a lot better then any other aluminum wire I've tried so far.
Old May 10th, 2010, 09:03 PM   #2
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Thats damn good for a spool gun!
Old May 10th, 2010, 09:36 PM   #3
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
Looks a lot nicer than my welds with my spool gun. I used .030 lincoln 4043 wire and it ran like crap but held up.....so far. What welder are you running the spool gun with?
Old May 11th, 2010, 07:53 AM   #4
CreativeFab
used to be Ironman
Lincoln Power Mig 200, the one with the Nascar sticker (which is why it welds so good)
Old May 11th, 2010, 08:17 AM   #5
Nuggets
I fix stuff!
Nuggets's Avatar
I had good luck with my spool gun but my TIG does a better job.
Old May 11th, 2010, 10:22 PM   #6
lgottler
lgottler's Avatar
We setup a grill at work next to the welder. We would toss a few pieces on there, while welding and feed the welder with the preheated parts. It welded twice as nice with the spool gun. But getting it to do the spray transfer is a PITA! I made a custom sized liner for our gun at work, slightly tighter with finer wire, made a big difference with tip stickings.
lgottler is offline   Reply With Quote
Old May 12th, 2010, 08:43 AM   #7
CreativeFab
used to be Ironman
I hear ya Lucas, I have cold starts with mine but when I get the heat set right it seems to flow nicely just off start. When possible I also try and downhill everything if it is a bench weld, preheating the critical stuff like radiators and intakes.
Page generated in 0.19902 seconds with 44 queries
