Where can i find Tie downs that aren't 30' long - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 21st, 2010, 10:31 PM   #21
robrocketanski
This weekend I am going to Bundy Hill and I went ahead and put some blocks of wood in my suspension and tightened the straps to that. After I chained both axles to the trailer. So the truck is as if it was bolted to the trailer.
robrocketanski is offline   Reply With Quote
Old May 22nd, 2010, 07:22 AM   #22
My trailer is dedicated to my jeep & I got tired of dealing with the extra length and cut mine. I've never regretted it. I have a couple extra spares that are full length that I carry for a "just in case". Never used them.
So, if your sole purpose for buying straps is to tie down your POS Zuk on your POS trailer to tow behind your POS Honda, cut them.
Old May 23rd, 2010, 10:50 AM   #23
Brods
Large releasable cable ties. Been using the same ones for a several years now. They also keep the straps neatly rolled up while in storage. Just make sure you get the UV resistant type.
Old May 31st, 2010, 07:58 PM   #24
scottie
Eye candy
scottie's Avatar
So, if your sole purpose for buying straps is to tie down your POS Zuk on your trailer to tow behind your toyota, cut them.
Fixed
Old May 31st, 2010, 08:46 PM   #25
Originally Posted by scottie View Post
Fixed
In that case, get two extra, one to keep the frame together, the other to act as a throttle plate retrun spring...
There are plenty of shorter straps through summit, jegs, others. They have various end hooks. And also cost more than regular long ones. The most cost effective option is the long ones, and cutting them short.
I keep 4 cut down to around 8ft, and 2-4 full length ones as well, for mixed tie down work.
Old June 4th, 2010, 01:02 AM   #26
busyfixin
Balls Deep
busyfixin's Avatar
I use chains. Usually G70 DOT vehicle transport chain. However, i do usually keep plenty of the 10k 27-30' cargo straps in the trailer basket. I use these to strap down cargo. I have cut some, and burned the end with a torch to keep from fraying, which often needs to be done to the long ones as well, as the factory burn doesn't last too long. if you have a chain rail on your trailer you should be buying the type with a flat hook, and they should be doubled back over themselves. If you have D-rings, the style with the round wire hooks will work, although they should be the flat steel snap style hooks like shown earlier, so they cant fall off should a failure of some sort occur.
If you leave the straps long, the best way to take care of the extra is to fold the extra back into the ratchet and then tighten it down. This cuts the length in half. Then fold it over itself in lengths about 12-20" long (depending on the length of "extra". When you've folded it over itself about 4-5 times, slip half of it under the handle and click it into the closed and locked position. The tension of the ratchet will hold the extra in place, and if it were to come loose, its only half as long, so its not flying all over nearly as bad.
probably the most important thing is to get a hook that matches your trailer, and a hook that matches the tow rig, or the axle strap. You may be best off to buy two flat hook style and two round hook style and use a flat hook ratchet with a round hook strap, and vise versa for the opposite end. This will give you a flat hook for the trailer end and a round hook to fit into the axle strap on the other.
Old August 5th, 2010, 09:39 PM   #27
chrsnrwd
chrsnrwd's Avatar
I just put the extra on the floor in the jeep and close the door on it, I'm lazy.
chrsnrwd is offline   Reply With Quote
Old September 6th, 2010, 06:25 PM   #28
rdyota
i black tape the extra up so its not flapping but also cut my 30fters down to 20ft and burned the ends to prevent fraying.
rdyota is offline   Reply With Quote
Page generated in 2.12602 seconds with 47 queries
