Where can i find Tie downs that aren't 30' long - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 9th, 2010, 08:47 AM   #1
scottie
Eye candy
scottie's Avatar
Default Where can i find Tie downs that aren't 30' long
I have a trailer and something to put on it, but i can't find tie downs that aren't 30' or 20' long.
Should i just deal with the extra length or try and find shorter ones.
Old May 9th, 2010, 10:39 AM   #2
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Cut them with a red hot knife.
Old May 9th, 2010, 10:43 AM   #3
whyme86
whyme86's Avatar
what size tires u running
whyme86 is offline   Reply With Quote
Old May 9th, 2010, 10:52 AM   #4
luvitmyjeep
broken
luvitmyjeep's Avatar
i was pissed 3 days after i cut mine. i would try to deal with them
luvitmyjeep is offline   Reply With Quote
Old May 9th, 2010, 11:22 AM   #5
CreativeFab
used to be Ironman
CreativeFab's Avatar
Fold over the extra if you do not want to cut them, bungee balls are your friend!
Old May 9th, 2010, 12:06 PM   #6
Yota Bill
X2
so many times I have been tempted to cut mine down, but I know as soon as I do, I will have a need for longer straps...alot of times I just tie down whatever vehicle is on the trailer, open the door and toss the excess strap inside
Old May 9th, 2010, 12:09 PM   #7
insaneoffroader
insaneoffroader's Avatar
x2
If parts ain't flyin' you ain't tryin'
insaneoffroader is offline   Reply With Quote
Old May 9th, 2010, 12:57 PM   #8
curbdog17
Mini Van
curbdog17's Avatar
I wrapped electric tape around mine then cut through the tape. the ends will not come apart this way.
Old May 9th, 2010, 01:25 PM   #9
koochman450r
koochman450r's Avatar
summit and jegs both have tie down kits in many different varieties. like axle straps, tire straps, chassis straps. check them out
you won this battle.
Old May 9th, 2010, 01:46 PM   #10
kickstand
circling the drain
kickstand's Avatar
fuckin scottie
Old May 9th, 2010, 02:47 PM   #11
95geo
newbie
95geo's Avatar
cut them with a really sharp knife or scissors, then take a red hot piece of steel and melt the ends so they dont fray. Ir you can just wrap the excess up with a bungee ball like Pat said. I've kicked myself in the ass many times for cutting my tie downs down to 15' or so. I could have used the extra length many times over again.
Old May 11th, 2010, 11:49 AM   #12
Bruster
ive got some 8fts from macs tie down.
Old May 14th, 2010, 09:51 AM   #13
nickb304
nickb304's Avatar
tiedown tamer
http://www.etrailer.com/p-EM58690.html
nickb304 is offline   Reply With Quote
Old May 14th, 2010, 10:08 AM   #14
bigbchevy
missmrgreenagain
bigbchevy's Avatar
fuckin scottie
x2
H.o.r.e
Old May 16th, 2010, 10:27 AM   #15
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
5,000 pound, 2 X 15 foot tie downs. These combined with some axel wraps should do the trick.
http://www.tractorsupply.com/trailer...00-lbs-3020130
Old May 16th, 2010, 10:31 AM   #16
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
I have these, but I've found that I'm not fond of the twist at the end where the hook is... Doesn't seem that I'm ever able to get a good pull, and the twisted metal is in theory a week point. I use these in comination with axel wraps. If you get the axel wraps, get the ones with the wear sleave on them to protect the strap from wearing on what ever you tie down.
http://www.tractorsupply.com/trailer...00-lbs-3020122
http://www.tractorsupply.com/trailer...00-lbs-3001770
Old May 17th, 2010, 06:10 PM   #17
Mclovin
"The Situation"
Mclovin's Avatar
i use these and they work great
http://cgi.ebay.com/ebaymotors/Auto-...Q5fAccessories
Old May 18th, 2010, 11:37 AM   #18
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
Those are pretty much a combination of what I posted.. the twist in the hook is theoretically a weak point. If you have D rings on your trailer, they are probley good, but if you have to hook to the side rail, they don't seem to work that well for me.
Old May 18th, 2010, 10:46 PM   #19
Yota Bill
I use those exact same Ericson axle straps, with the ratchet straps you posted above those
I also carry 3 straps that are around 30' (27'?) and a bunch of 1 inch ratchet straps, some bungee cords, a couple of chains, a few shackles, a frame hook, and the winch and pulley block...a 2-3 foot length of 2x10 is also handy to have when you have to pick up a car that may scrape when breaking over the ramps onto the trailer deck...a couple of bottle jacks are also nice to have when loading lower cars, to jack up the front of the trailer and lower the rear, 1 on each front corner, rather then using the trailer jack and risking damage to it, and the 2 corners suported makes it more stable, IMO
Old May 21st, 2010, 09:29 PM   #20
robrocketanski
Man, this is the the bane of my towing too. I coil up the extra and use 2 wire ties to hold it in a loop. Here is what I do.
robrocketanski is offline   Reply With Quote
Page generated in 0.34879 seconds with 83 queries
