1978 ford f-150 351M - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 8th, 2010, 11:24 PM   #1
fordman390
Default 1978 ford f-150 351M
i just bought a 1978 ford f-150 "camper special" has a 351m/400 motor and it seems extremly doggy i was wondering what i could do to get more power, or possible even switch it out for a 390 or a 460.
fordman390 is offline   Reply With Quote
Old May 8th, 2010, 11:28 PM   #2
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
check the gearing. My dad had a 351M ford that was a beast till he blew it up and switched to Chevy. LOL Also he had an issue that made it not want to get up and go for crap. The stupid master cyclinder wasn't set right or something like that anyway the front brakes were too tight and wouldn't release. Changed the master cyclinder and was good to go.
Old May 8th, 2010, 11:30 PM   #3
masterbeatty
masterbeatty's Avatar
headers, ditch the 2barrel and go with a nice 4. a cam, but my 400 runs like a monster with 35s and nothing but duals
Old May 10th, 2010, 08:28 PM   #4
ryan_0731
Default accelerator pump
if it has a motocraft 2 barrel on it check to see that the accelerator pump is working. Usually it squirts fine the first time you step on it but when you let off the gas it returns slow, in turn when you hit the throttle again the pump hasn't had time to refill and give another squirt, however this usually leaves you with a dead spot, kind of acts like its running out of fuel, you didnt mention how many miles on it, maybe its just getting tired. if not I would check for any vacuum leaks and make sure fuel delivery to the carb isn't an issue(especially the screw in fuel filters on the front of most motocraft 2 barrels, way to small and plug with out much of anything in them)
ryan_0731 is offline   Reply With Quote
Old May 11th, 2010, 08:11 PM   #5
fordman390
Yea im sure its tired its 120,000 but iwas planing on rebuilding it so i was wondering if anyone gots some sugestions on how to build it, and what parts are the best parts, i dont need a hot rod , but i dont want somen with no getupngo
Old May 12th, 2010, 07:32 AM   #6
fsumotorhead
N8KVB
fsumotorhead's Avatar
is it a 351 or a 400?
It doesn't take too much to make decent power out of a 400.
Both engines seem to run really well with an aftermarket intake maifold. We put an edelbrock single plane manifold with a 4 barrel on my buddys 400, it seemed to scream.
The biggest change in performance came from changine the gear ratio though, the truck hade 3.50 gears and we swapped them out for 4.88s
Old May 13th, 2010, 12:14 AM   #7
fordman390
well what it says is 351m/400 and im pretty sure i found me a 351W so im just gonna put that in there instead of dealing with the modified, windsor is the way to go
Old May 13th, 2010, 09:05 AM   #8
fsumotorhead
N8KVB
the M in the 351M is for Michigan Casting Center, not "modified", as opposed to 351C (clevland), or 351W (windsor)
the 351M and 400M are different engines, the 400 (6.6) is much less common
Old May 13th, 2010, 09:44 PM   #9
fordman390
ok well wld u recomend getting the 351w instead of the 351m?
and on the motor it says 351m/400
so i unno
Old May 14th, 2010, 06:22 AM   #10
fsumotorhead
N8KVB
for me i would stick with the stock engine, because i'm cheap and lazy
If you feel like replacing the transmission, motor mounts, radiator, lines, hoses, etc then by all means jump on it.
If i were to "build" a performance engine, it would not be the 351M, it would probably look for a 460, that way i can re-use the transmission at least, and all other 460 swap parts can be bought easily.
Old May 14th, 2010, 08:43 AM   #11
ATOMIC_BADBOY
Shake n Bake
ATOMIC_BADBOY's Avatar
everything you need to know is right here http://web.archive.org/web/200712161...s/parts01.html
ATOMIC_BADBOY is offline   Reply With Quote
Old May 14th, 2010, 11:05 AM   #12
TurdBronco
If rebuilding:
Mill the heads about .030
If its a 351, get a 400 crank and 400 flat top pistons(hard to find, badger was one manufacturer)
new good timing chain
rv cam
4bbl carb
good to go.
460's are fine but more work and more expensive, different exhaust, ps pump brackets, motor mounts.
Old May 15th, 2010, 01:02 AM   #13
fordman390
so everything is diffrent from a 351m to a 351w? like motor mounts, and even gotta get a new transmission?
Old May 27th, 2010, 02:26 AM   #14
Fraser
Fraser's Avatar
yaa. the windsor has a sbf bellhousing pattern, and if i remember correctly the M series stuff shares the bell pattern of the 385 series big block [429,460]. very similar, if not the same. i wouldnt be sure on the mounts tho, prob different somehow
Old October 8th, 2010, 02:32 AM   #15
my broke ass ford
if its a 351m not a 400 go have 351c pistons fitted on the rods that would be cheaper and youll get more compression with cleavland pistons a buddy of mine mike briggs built on of these with mild cam 454 chevy roller rockers after market intake headers made over 400hp dynoed that was rwhp in a 80's bronco i think he did a little porting on the heads not sure
my broke ass ford is offline   Reply With Quote
Old October 8th, 2010, 12:03 PM   #16
Fraser
Fraser's Avatar
hm, never heard of using the cleveland pistons before, nice.
Old October 8th, 2010, 08:17 PM   #17
my broke ass ford
hot rod mag did a pice on this to theres alot of hp to free up in these motors
Old October 8th, 2010, 11:00 PM   #18
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Actually both the 351 and 400 are identical in every aspect except the rotating assembly. And the "m" in the designation doesn't have a clear meaning, it could me modified, or michigan but the michigan part doesn't really hold water since they were quite a few of these engines built in the cleveland plant. Also, just a little tidbit the "m" engines actually belong to the same engine family at the cleveland's (fords 335 series engines).
Aside from buying motor mounts and an oil pan kit there isn't a whole lot to putting a 385 series engine into a vehicle that had an "M" engine to start with. You can now find the mounts for less that $50 on ebay and they are identical to the mounts I paid over $150 for when I did my swap. The p/s pump bracket can be modified to work on the 460 without much issue. The main benefits of doing the 460 is more HP and TQ with a budget build and an almost unlimited amount of aftermarket support and upgrades. There are many many stroker kits, head options, intake and header options, and other performance parts for the 460. And from a budget build stand point wont cost much more to build than the 351M (except the cost of buying the 460 core).
When I did mine I went for the 460 and never looked back and I love it. Mine is a very basic build with nothing fancy. Bigger cam, reworked stock D3 heads, flat top pistons and an edelbrock performer intake and 750 cfm carb. I have excellent low end torque and a reliable, durable engine the does everything I every ask of it. Flat out the M engines don't hold a candle to the 385 series what so ever.
Like they say "THERE'S NO REPLACEMENT FOR DISPLACEMENT"
Also, here is some good info on the 351M/400 boat anchors http://www.projectbronco.com/History..._ford_351m.htm
Page generated in 0.58829 seconds with 77 queries
