97 dodge ram 4x4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 6th, 2010, 08:25 PM   #1
6boltfreak
6boltfreak's Avatar
Send a message via Yahoo to 6boltfreak
Default 97 dodge ram 4x4
looking to go a better axel swap. need something that is better just getting ready for trails in the dodge need something that will hold up to the abuse. help me please.
6boltfreak is offline   Reply With Quote
Old May 7th, 2010, 04:42 PM   #2
noodles
give 'er sh*t ay?
noodles's Avatar
what do you have? 1/2 ton, 3/4 ton 1 ton? what are you going to do to the truck?? need more info.
the axles between trucks are pretty much a bolt swap job. not sure about the drive shafts, never seen if they fit or not. but the suspension is the same. I know on a 94 there was 2 different widths of leaf springs. so might watch out for that. Not sure if the 97's had that set up also.
Old May 8th, 2010, 12:17 AM   #3
6boltfreak
6boltfreak's Avatar
i just really want something stronger its a 1500 and i haul my 25ft gooseneck with it. the truck has no issue but the ass squats so damn bad and i am afarid on the farm i am going to break the axels.
Old May 8th, 2010, 12:17 AM   #4
6boltfreak
6boltfreak's Avatar
Old May 21st, 2010, 10:29 AM   #5
matt440rev
there was a guy on that had a dodge 60 front for that thing for like $300. aside from what most say, the dodge 60 is pretty tough.
matt440rev is offline   Reply With Quote
Old May 21st, 2010, 10:45 AM   #6
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
but a set of 1 ton axles from a 3500 and swap them in. heres a front 60 for sale. http://www.greatlakes4x4.com/showthr...=172932&page=2 and heres a rear to go with it.
Axle Part(s): Dana 70 rear axle. 4.56 gear, 8 bolt floating axles - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 24th, 2010, 11:04 AM   #7
sonic
sonic's Avatar
a set of Dana 60's pretty much will bolt right in. i grabbed a set for $300. shop around people are giving em away these days. remember you will need new rims at least and the drives shaft in the reasr will need to be shortend and you will need conversion u joints
sonic is offline   Reply With Quote
Old May 24th, 2010, 11:07 AM   #8
Freak
Wheelin the HD
Freak's Avatar
swapping in a 6 isn't going to reduce the sag from the weight... hes going to need springs for that... then its going to be easy to over load and BAM bent frame... you need a bigger truck if you dont feel comfortable hauling the trailer with what you have.
Old May 24th, 2010, 10:09 PM   #9
matt440rev
i really doubt that the frame would bend from using 3/4ton springs, if that frame bends theres bigger issues to worry about.
id upgrade to 3/4ton springs and axles if your happy with the truck as it is. there cheap and work great. id put helper bags on your stock rear springs that way you still have a decent unladed ride. as for the front, just throw in a set of diesel coils and theres lift and no sag. (i have diesel coils if your intrested)
matt
Old May 24th, 2010, 10:14 PM   #10
Freak
Wheelin the HD
Freak's Avatar
haha, yes, springs are going to bend the frame! woo! your going to bend a 1/2 ton frame buy acting like its a 3/4 ton... trust me, I know a guy that did this.
Old May 24th, 2010, 10:58 PM   #11
osteologation
Everyday I'm Shufflin'
osteologation's Avatar
idk about dodges but i know the older f series fords the 1/2 ton used c channel frames an the 3/4 ton and 1 ton used boxed frames.
id say use a airbag load leveling setup. but a 25ft gooseneck seems liek a pretty big trailer for a 1/2 ton.
Old May 25th, 2010, 08:33 PM   #12
6boltfreak
6boltfreak's Avatar
i have already used the gooseneck but some of the loads really bottom out the springs bu ti think your right when you say i need a bigger truck.
Old January 4th, 2011, 06:11 PM   #13
stumpjumper_09
that 1500 should have the corp 8.75 that is supposed to be as strong as the 60 I wouldn't worry about that.
stumpjumper_09 is offline   Reply With Quote
Old January 5th, 2011, 09:39 PM   #14
mprmn08
mprmn08's Avatar
throw some 60s like everyone said and some 2500 or 3500 springs. the SPRINGS will not bend the frame but maybe treating it like something other then a 1500 will. as for the widths i believe the only difference is the 2500 and 3500 axles have 3 inch spring perches and the 1500 only has 2.5 but not for sure. heard that once.
Old January 6th, 2011, 06:25 AM   #15
Flat_Black
The Dodge Guy
Flat_Black's Avatar
not even close. the 8 3/4 was last used in 79ish and NEVER EVER in the 2nd gen trucks. please get your facts right befor posting in the tech section. the axles in a 2nd gen 1500 are front dana 44 and rear chrysler 9.25. the 9.25 has been in the ram line since the mid 70s. again do your research befor posting.
yes 2nd gen 3/4 and 1tons have a 3" wide spring
Old January 6th, 2011, 10:48 PM   #16
noodles
give 'er sh*t ay?
noodles's Avatar
Didnt some of the 3/4 tons come with 2.5" springs. I though I have ran in to them before. I could be wrong though. I do know when I have bought springs for the 1/2 ton there was the option for the 3" wide ones.
i wouldnt be worried about the rear axle. They have thoes in 3/4 ton trucks behind the deisle.
I might have 3/4 springs laying around.. Ill have to dig though my parts truck if your intrested. but I agree with the guys, you just need a bigger truck.
Old January 9th, 2011, 07:20 PM   #17
Tie Dyed
O.G.
Tie Dyed's Avatar
Send a message via AIM to Tie Dyed
I *believe* that the difference is in the light duty 3/4 ton vs heavy duty. When thay had a light duty 3/4 ton is was with the 9.25 and a 44. The light duty 3/4 ton was only an option at the start of the 2nd gens, up to 97 I think, but it could be a year or to later, or a year earlier.
No, the V10 or diesel had a 70 or 80 rear. The difference was the autos had a 70, and the stick/dually had the 80.
I would just go out and look for a 3/4 2nd gen, then you would have nothing to worry about. I see about 10 mpg in my v10 and that is loaded or unloaded. The only thing I wish is that I had the stick vs. the auto. In the 2nd gens you could not get a 1 ton in a non-dually, so that is why you see so many 3/4 rolling around.
2000 XJ with a 3 inch body lift
Tie Dyed is offline   Reply With Quote
Old January 29th, 2011, 07:39 PM   #18
stumpjumper_09
Originally Posted by Flat_Black View Post
not even close. the 8 3/4 were in the befor the 80s and NEVER EVER in the 2nd gen trucks. please get your facts right befor posting in the tech section. the axles in a 2nd gen 1500 are front dana 44 and rear chrysler 9.25. the 9.25 has been in the ram line since the mid 70s. again do your research befor posting.
got my numbers mixed up my bad.... the rest of my statement still stands...
Old January 30th, 2011, 01:09 PM   #19
Flat_Black
The Dodge Guy
Flat_Black's Avatar
so you belive a 9.25 is as strong as a 60? where did you do you get your info from?
Old January 30th, 2011, 05:09 PM   #20
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Good job bringing up a old thread
Page generated in 3.59193 seconds with 84 queries
