TH350 now squeals instead of goes into gear - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 5th, 2010, 07:01 PM   #1
Judo
Science Patrol
Judo's Avatar
Default TH350 now squeals instead of goes into gear
Was adjusting my transfer case linkage today and finally got it dialed in decent. I was testing out the 4Low and 4Hi in Drive with a mild break applied to provide a little stress. I mean a LITTLE stress. was working and then suddenly the trans seem to have slipped. Now all gears forward and reverse seem to cause a squealing or slipping noise in the trans like its trying to work though the clutch but never engages fully. I will be dropping the pan to check fluids levels and general inspection. Any other suggestions (besides not trying to drive with the brake on)
Judo is offline   Reply With Quote
Old May 7th, 2010, 06:39 AM   #2
Judo
Science Patrol
Judo's Avatar
After further investigation it does go in gear both reverse and drive. The noise seems to be coming from the torque converter area. Trans and motor mounts are straight and strong. I am thinking about a sea foam trans treatment, mild drive and then a trans flush and fill.
Old May 7th, 2010, 07:47 AM   #3
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Make sure the converter bolts are tight. Mine made a strange noise for a while and it turned out to be loose bolts.
Old May 7th, 2010, 07:06 PM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
when the pump bushing went on my `01 GMC the front of the trans sounded like a turbo charger spooling up. it had all of 4400 miles on it when it went.
Yetti
Old May 14th, 2010, 09:50 PM   #5
Judo
Science Patrol
Judo's Avatar
Did a little Seafoam treatment to the transmission....within 20 miles of driving the noise is completely gone. I will be flushing the foam out and replacing filter and fluid next week. Best $10 I have spent on this truck! I'm really amazed how much this effected not only the noise but also the shifting. It really smoothed things out.
Page generated in 0.43038 seconds with 38 queries
