2004 Silverado Vehicle Speed Recalibration NEED HELP! JET PERFORMANCE DOESN'T KNOW - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 5th, 2010, 10:44 AM   #1
projecthellraiser
projecthellraiser's Avatar
Default 2004 Silverado Vehicle Speed Recalibration NEED HELP! JET PERFORMANCE DOESN'T KNOW
I recently purchased a jet performance Speed recailbration module.
I have a 2004 Chevy Silverado 2wd crew cab. I purchased the Accu-Speed brand new from a member, and well after 2 long days of not being able to get a correct answer from JET Performance nor from Superlift (same module different company even the instructions are the same)
the Manufacturer Item #50108
The problem I have is:
To be able to connect to the VSS signal wire your suppose to go PIN 50 on the PCM. After you find said PIN 50 your suppose to splice into it and essentially it adds resistance to the circuit and controls the signal to the PCM. (wire the module in series)
Here is is the problem, there is NO PIN 50! I checked ALLDATA and Mitchell's and both show a PIN 50 as VSS out to the Instrument Panel.
After I started talking to some of my professors, we looked through Mitchell and sure enough the VSS is an AC signal. So that means it has a positive signal and a negitive signal thru 2 wires.
I found these wires, they are:
PIN 20 LT Green/BLK low signal
PIN 21 PPL/ White high signal
I am wondering where I am suppose to splice into?
Mitchell shows a PIN 50 going to the Instrument panel as a DK Green/ white wire that goes to PIN A4 in the cluster. But there isn't a damn PIN 50.
Jet and Superlift dont understand this. They both say I must have some super uncommon truck. which I dont. they dont even understand what Im saying when there isnt a PIN 50. their response is "that cant be we have sold 1000's of these and never had this complaint"
so any GM techs please chime in or someone that has done this install because im at a loss. I really dont want to start cutting into the PCM harness for no reason.
Lance
projecthellraiser is offline   Reply With Quote
Old May 5th, 2010, 01:12 PM   #2
IFS SUCKS
I like trees
IFS SUCKS's Avatar
Pin B/wire color = LT GRN/BLK
,circuit 822 low signal
pin A/wire = PPL/WHT
,circuit822 high signal
Is this what you needed?
IFS SUCKS is offline   Reply With Quote
Old May 5th, 2010, 03:49 PM   #3
Disturban
Disturban's Avatar
Why do you even have to splice into wires? You have an OBDII computer and most programmers can recalibrate your speedometer...splicing into wires is a hack job. Any transmission shop should be able to recalibrate it for you.
Old May 5th, 2010, 04:09 PM   #4
95geo
newbie
95geo's Avatar
How about this.....
And dont buy garbage anymore... that is a software only modification, no wiring needed. You just need to change the pulses per mile in the ECM, trivial from a tuning/calibration standpoint.
Old May 5th, 2010, 07:46 PM   #5
projecthellraiser
I understand it can be done with a tune. I have it currently done but I have 2 completely different tires per season I run, and the ECM cannot completely handle the difference. nor the new gear install.
I bought the jet module for cheap on here and I see why it was.
I know there is a low and high signal. but which one does it use? I HAVE NO PIN 50 from the ECM!!!!!!! trust me I have checked there is no green and white wire. only a weather pack plug.
We have a tech 2 at college but I like the idea of being able to change it if im not there.
say when I go to get me MBA in a year and a half.
Also splicing isn't hacking as long as its done correctly. (no I dont use scotch locs and electrical tape either) all its doing is modifying a pulse signal, so if the connections sealed and hidden how is it hacked?
Which pulse is what I need to know. high side or low.
and why does it only modify one signal not both of them? the positive and negitive signal? the unit has 4 wires. keyed power, ground, input side of wire and pcm side of wire. that is all.
Old May 7th, 2010, 12:57 PM   #6
Red97
Your 22's are gay! lol sell them and just run your 285's get it tuned once and be done with it.
Red97 is offline   Reply With Quote
Old May 7th, 2010, 01:46 PM   #7
MILKTOST
Flexes like a bulldozer
MILKTOST's Avatar
Pin 50 of ecm connector #2, this is the green connector, not the red connector.
This circuit is the signal circuit from the pcm to the gage cluster.
The plug in module modifies the pcm output signal, not the vss input signal.
If you still cannot find pin 50, you can splice into A4 at the gage cluster. Dark green/white wire. This is the same circuit that is supposed to be at terminal 50
of ecm.
Good luck.
MILKTOST is offline   Reply With Quote
Old May 9th, 2010, 03:07 AM   #8
projecthellraiser
Same thing geo said.
got it setup last night. thanks again.
for some reason the instructions I have, have me going to the damn wrong connector. Stupid Engineers at Jet. lol
Page generated in 0.31558 seconds with 48 queries
