TBI vs. carburetor manifolds. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 4th, 2010, 05:31 PM   #1
Nuggets
I fix stuff!
Nuggets's Avatar
Default TBI vs. carburetor manifolds.
I have a early 90s TBI motor that I want to put a carb on. Do the old school carb manifolds bolt right up?
Note: This engine will be installed in a project and I don't have any of the computer goodies, so carburetor it will be.
Old May 4th, 2010, 05:47 PM   #2
SBC YJ
Heavy Chevy
SBC YJ's Avatar
i'm about 85% sure they do i don't think it changed to vortec heads
SBC YJ is offline   Reply With Quote
Old May 4th, 2010, 07:50 PM   #3
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
you can put the old intakes on the `87 and newer heads but the center two bolts are 15* tilted up. I have always just drilled the holes bigger and used an old rocker ball on the bolt to equalize the load when tightened. if its not a show piece then its a no brainier, its a show piece then buy an intake that has the correct bosses machined into it.
Yetti
Old May 4th, 2010, 10:19 PM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
X2. everything but the center 2 bolt holes are the same.
Page generated in 0.16272 seconds with 35 queries
