MC Hammer tj - Page 14 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 20th, 2013, 07:04 PM   #261
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
Originally Posted by chadcooper55 View Post
It isn't mounted yet, it is just sitting there. I am going to try to squeeze it in there if I can but if not I will put it in the back. Gordy, one of the owners of rocksolid performance, has his mounted like that in his "brush buster" buggy and it seems to work fine. When I get the hood mocked up I will see if I have enough room.
Alumcj had his mounted like that in his ultra 4 car, he couldnt get fans to live. talked with spal and they told him he had two issues. One being that the fan bearings are not really built to be on a constant angle and then he also had a set of fans with unsealed bearings.
he mounted his radiator upright and hasnt had a problem since.
Old February 20th, 2013, 07:30 PM   #262
bluminade
Bluminade Has Arrived
bluminade's Avatar
you will change your mind at least 5 or 6 time before it gets mounted anyway. hahaha
bluminade is offline   Reply With Quote
Old February 20th, 2013, 07:44 PM   #263
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Originally Posted by jeepsAmutt View Post
Looks good Chad!
Sent from my SPH-L710 using Tapatalk 2
I'm leaving for Colorado not this Sunday but next. You should stop by and have a beer and grab the bender next week!
Screw you wade, you act like you know me or something
Hosejockey, I will definitely keep that in my mind with the radiator. I was hoping to not have to mount it in back but I might end up having to if I can't get it more vertical up front. I won't know how it will fit until I get the shocks on and winch mounted. I don't have a lot of room vertically because how far my axle comes up into the engine compartment.
Old February 20th, 2013, 08:06 PM   #264
jeepsAmutt
jeepsAmutt's Avatar
Lmk when, I'll bring the beer. And something that's been taking up space!
jeepsAmutt is offline   Reply With Quote
Old February 20th, 2013, 08:08 PM   #265
chadcooper55
I'm going to use it this weekend but after that I am done until I get home in 6 months. Anytime you are free next week just let me know. My schedule is pretty relaxed right now.
Old February 22nd, 2013, 07:01 PM   #266
chadcooper55
ID:	102323Click image for larger version
ID:	102324Click image for larger version
I still have to build some pieces to mount the seats to the tube but at least I got the seats in so I could see how much headroom I have. Right now I have about 6 1/2" above my head to the cage but I'm guessing I will lose an inch with the mounts. I am 6'2" tall. I used 1 3/4 .095 wall for the interior tubing.
Old February 22nd, 2013, 07:03 PM   #267
chadcooper55
I also moved my rear upper links mounts back about 4" and down just a pinch. They are perfectly level at ride height now and out of the way of my seats.
Old February 25th, 2013, 06:56 PM   #268
chadcooper55
It's a sad day....
Getting it ready to drag it back to the storage barn where it will sit being lonely until next fall. I'm bummed to be done working for a while. I'm going to go nuts in Colorado with no big projects.
Old February 25th, 2013, 07:31 PM   #269
KCameron13
Weekend Warrior
KCameron13's Avatar
At least there will be a ton of parts when you get back. Something to look forward to.
KCameron13 is offline   Reply With Quote
Old February 25th, 2013, 07:41 PM   #270
chadcooper55
I'm already looking forward to getting home and putting them all on!
Old February 25th, 2013, 07:47 PM   #271
kingkongf150
kingkongf150's Avatar
Hey just curious. What does it look like if you look over your right and left shoulders. You should simulate gas tanks and what not with propane tanks and trash cans and then take some pix of all views. Oh and also I hope you have been using your floor and walls as levels and squares.
kingkongf150 is offline   Reply With Quote
Old February 25th, 2013, 07:51 PM   #272
chadcooper55
I can get those pictures for you mike! I'll drag it out back with the tractor tomorrow and put it in some real life scenarios for ya!
Old February 25th, 2013, 08:06 PM   #273
kingkongf150
Good good make sure to get every scenario you can you never know what you'll run into out there in the real world.
Old February 25th, 2013, 09:19 PM   #274
beejers
always building
beejers's Avatar
beejers is offline   Reply With Quote
Old February 28th, 2013, 07:36 AM   #275
chadcooper55
what are some cheapish mods i can do to the 5.3 to add a little horsepower? im not looking to spend a ton on the motor but i would like to give it a little extra get up and go.
Old February 28th, 2013, 08:43 AM   #276
firehawk
Live Action!
firehawk's Avatar
Cam and a tune.
Head work.
Old February 28th, 2013, 08:52 AM   #277
chadcooper55
Cam and a tune.
Head work.
next question.
is it worth putting it into the 5.3 or should i just find a 6.0? now is the time to do it if it is worth the swap since i dont have anything hooked up yet.
Old February 28th, 2013, 09:14 AM   #278
firehawk
Live Action!
firehawk's Avatar
next question.
It all depends on what you want out of it. I would think a warmed up 5.3 should be plenty but that does not mean it is worth it over going with a 6.0.
I am no expert so wait for a better response.
I have the stock 4.0 in my Jeep so a 5.3 would be sweet, but a 6.0 would be sweeter. If I could swing it I would go with a 6.2 or a mini stroked version of one but do you need that kind of power for offroading, no.
Mostly depends on what you want and what your budget allows.
Old February 28th, 2013, 09:21 AM   #279
chadcooper55
I have done a fair amount of reading on ls1 forum but most of their info pertains to a street car with long duration cams and high stall converters. I'm no motor expert but I know that isn't what I want for Offroad. I just want a good motor that has some get up and go and I don't want to sink too much money into a 5.3 and regret it.
Old February 28th, 2013, 09:23 AM   #280
firehawk
Live Action!
firehawk's Avatar
Not saying you won't get good info here but you might want to get a broader spectrum and try Pirate. Or just ask our resident 1%er.
Page generated in 0.50027 seconds with 84 queries
