Where to get special u joints for rear axle on 95 F250 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 3rd, 2010, 11:51 PM   #1
MilwaukeeF350
Dan
Default Where to get special u joints for rear axle on 95 F250
Here issues there are different size.
New u joint were for 95 F250 with original rear axle so I swap with 91 F250's rear axle.
Here issues that 91 F250's rear axle yoke are bigger than original rear axle.
Someone at FTE say there are u joint with 2 different cap size.
Well there are huge issues that 91 F250's rear axle aren't original it came from 460 or 7.3L diesel since F250 only have 351W. Cab claim gear is 4.10 but rear axle is 3.55.
Old May 3rd, 2010, 11:55 PM   #2
jon_xj90
fake it till you make it.
jon_xj90's Avatar
you just need to identify what the origional u-joints were, such as 1350, 1410, i had to get a bastard joint for an 8.8 swap in a yj and my local napa found it for me right away!
jon_xj90 is offline   Reply With Quote
Old May 4th, 2010, 12:01 AM   #3
MilwaukeeF350
Dan
I could try
I want show you picture so you can understand what I mean.
I get annoy vibrant at 30-40 mph because wrong u joint.
You can see that black gap where seal is that are loose badly.
Old May 4th, 2010, 04:54 PM   #4
MilwaukeeF350
Dan
Ok almost all stores I have call are dumbass.
They was WHAT there are no cross u joints like you request.
I am sure anyone of you been in this spot. Where can we get original size and bigger size.
I am think that rear axle came from 460 or diesel.
Old May 5th, 2010, 05:49 PM   #5
fsumotorhead
N8KVB
fsumotorhead's Avatar
looks like the pinion is leaking, pull the yoke off fix the seal and swap yokes with the old axle before reassembly
Old May 5th, 2010, 05:53 PM   #6
Bones
Bones's Avatar
Why are you blaming them? Get out calipers, find out what size Ujoint you need on the driveshaft side and which side you need on the axle yoke side, and maybe the stores would actually be able to help you.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old May 5th, 2010, 05:58 PM   #7
Hunter9
Not Right!
Hunter9's Avatar
Find a good traditional parts store (Napa, Auto Value, CQ, etc) and find the guy that has been in the business for at least 15-20 years. He will be able to find it with his eyes closed.
This is honestly not that big of a deal to figure out if you have the old ujoints (from both the axle and the shaft) or at least the yoke and joint that fits the shaft.
And as stated above, get a new seal while you have the yoke off.
Hunter9 is offline   Reply With Quote
Old May 5th, 2010, 08:13 PM   #8
Nvrenuf
Nvrenuf's Avatar
Here is a link that will give measurements and also a link on the page to conversion u-joints
Old May 5th, 2010, 08:39 PM   #9
don4life
don4life's Avatar
even autozone has a ujoint guide its finding someone smart enough to know how to use it
don4life is offline   Reply With Quote
Old May 5th, 2010, 08:44 PM   #10
MilwaukeeF350
Dan
Bones
when I call them on phone they were act like they see deer behind you. They say WHAT crossjoint u joint then they say NO they only sell u joint with same size.
Ok I went to Napa. Manager have no idea what I am asked so he asked new worker.
Worker couldn't find right u joints. We measure with my capilir. We try 12 different u joints they not fit it.
Well They say they never see like that.
Then I went to get Van which have dana 60. I measure it almost exact one.
Pinion isn't leak gear oil anymore. They leak before Owner use for cement business which have 3-4K pounds on it.
Old May 5th, 2010, 09:55 PM   #11
fsumotorhead
N8KVB
Bones
if you talk like you type (i hope not) it's no wonder the parts store treats you like a retard
Old May 5th, 2010, 09:59 PM   #12
buttercr125
I work out
buttercr125's Avatar
x2
Old May 5th, 2010, 10:28 PM   #13
MilwaukeeF350
Dan
You think it great idea to pissed off people who can't hear anything.
Most workers I deal are 25 or young age. There used to be lot old guys work but now they just gone.
Old June 11th, 2010, 12:51 PM   #14
sandfox4
napadave
sandfox4's Avatar
tell the napa guys to look in their precision u joint book on page 336 and higher, that shows u joints by size, do u have the measurements, and whether they are inside or outside lock rings, and i'll look it up, i have only worked at a napa for 24 years, sell these things all the time, but i consider myself a cut above
sandfox4 is offline   Reply With Quote
Old June 11th, 2010, 04:02 PM   #15
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Originally Posted by buttercr125 View Post
x2
Walk a mile in his shoes, then say that.
Old June 11th, 2010, 04:05 PM   #16
Jeeperz Creeperz
GL 4x4 Vendors
Good information!
Page generated in 0.31044 seconds with 71 queries
