SimpleTech 2GB Industrial CompactFlash CF Memory Card - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 3rd, 2006, 11:58 AM   #1
cornfed
I have an avatar. Yippee.
cornfed's Avatar
Default SimpleTech 2GB Industrial CompactFlash CF Memory Card
Used, will not ship in original packaging. I have 4 of these available. These are the industrail grade version, not consumer grade. I also have IDE adapters for these cards available. $75/card, $10/adapter. Located in Ann Arbor. Can ship/mail. PM or post up if interested.
Stats from SimpleTech:
CFA 2.0 and ATA-4 Compatibility • Support for PCMCIA I/O, Memory and True-IDE Interfaces • Form Factors: CompactFlash Type I and II (see Ordering Infomation for type specific to capacity) • Endurance Guarantee of 2,000,000 Write/Erase Cycles • CIS (Card Information Structure) Programmed into 256 Bytes of Internal Memory • Compatible with PC Card and Socket Services (Release 2.1 or later) • 5V or 3.3V Power Supply • Completely Solid-State (No Moving Parts) • Standard ECC Engine • • Other Features Available (inquire for more information) -Power Down Protection. A built-in feature that protects the card from losing data during a write operation when a lost of power or an unexpected removal from the host system occurred. -Endurance Status Monitor. A firmware option that allows applications to estimate the remaining life span of the device. - Password Protection/Write Protection. A custom utility software that allows the administrator and user to set passwords for up to four partitions. Ordering Information (continued from column on right) Adapters he SimpleTech SLCFxxxJ(T2)(I)(U)-(F)(S) are CompactFlash Cards with 128MB to 8GB of nonvolatile storage. The cards use a flash memory controller that provides a fully compatible CompactFlash interface for the flash memory. SimpleTech OEM CompactFlash cards are the product of choice in applications requiring high reliability and high tolerance to shock, vibration, humidity, altitude, and temperature. Because there are no moving parts to service or maintain, CompactFlash cards are reliable alternatives to mechanical hard disk drives for high availability and mission critical applications. While the inherent ruggedness and reliability of solid state storage relative to rotating hard drives is intuitive, new applications for OEM CompactFlash cards are emerging due to the low cost per usable megabyte. Most applications using embedded operating systems such as VxWorks™, Windows XP/embedded™, and Linux™ don’t have multi-gigabyte data storage requirements, and therefore a cost savings can be realized when using this robust media. Part Number CF Form Factor PC Card Form Factor
cornfed is online now   Reply With Quote
Page generated in 0.25079 seconds with 26 queries
