confused????? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 3rd, 2010, 09:23 PM   #1
rehab532
rehab532's Avatar
Default confused?????
is a 390 a big or small block?
rehab532 is offline   Reply With Quote
Old May 3rd, 2010, 09:44 PM   #2
ryan_0731
they are kind of their own block compared to the more common 289, 302,351, 429 and 460. called a FE, or y block( pretty sure they have their own bellhousing) I guess if I had to label them it would be big block due to weight and heavy structure of block and head castings, I dont know if this will help or not
ryan_0731 is offline   Reply With Quote
Old May 3rd, 2010, 09:47 PM   #3
curbdog17
Mini Van
curbdog17's Avatar
Big Block
Thats what I have always called them.
Old May 3rd, 2010, 10:20 PM   #4
trailranger
RESPECT MY AUTHORITAH!!!!
trailranger's Avatar
big block
trailranger is offline   Reply With Quote
Old May 3rd, 2010, 10:22 PM   #5
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
do you mean as in bellhosing pattern? or just catagory?
I do seem to recall them having their own bellhousing pattern (which would also fit with Ford's standards for engine families)
I'd figure they're a big block. The 427's and 428's (different from the 429's) were FE's too weren't they?
Old May 3rd, 2010, 10:33 PM   #6
ryan_0731
both the 427 and 428 are fe motors i think ford had a hard time makimg up there mind, but atleast it gives us some neat motors to look at, like for instance the 427 ohc motor
Old May 3rd, 2010, 11:12 PM   #7
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Ford_FE_engine Ford_FE_engine
Some Good info. They even give reason for the 427 and 428 being made. (428 was cheaper and faster to build)
Old May 4th, 2010, 06:10 PM   #8
rehab532
rehab532's Avatar
the reason im asking is i wanted to put a 351m in a truck that has a 390 motor in it,if the 390 is junk. just wondering if it would bolt up to the tranny or not.all help appreciated, thanx
Old May 5th, 2010, 12:45 AM   #9
bigblockford79
Big Block Ranger
My suggestion to you would be to go with a 460 if you swap anything in place of the 390. The reason being:
-You will need new motor mounts for either swap (cost is basically the same)
-You will need a different transmission that had the 385-series bellhousing (351m and 460 use the same trans)
Basically, besides the cost of the engine itself the cost for the swap will be the same to have a boat anchor(351M) or something you can upgrade internals into later and really have something(460). There also isn't much aftermarket support for modified engine swaps since most people are ripping them out for 460's anyway.
I was not able to find a swap motor mount for the 390 to 351m that was publicly available, most likely you will need to make your own. As for the 460 swap, I found these mounts on ebay.
http://cgi.ebay.com/ebaymotors/Ford-...item3a5a87b818
There were many others to choose from as well.
Another thing to consider is the oil pan. The 460 may need a conversion pan kit or a pan off a 1980 - newer truck to fit in the frame rails, since 460's were more abundant in cars. The oil pan kit from Ford Racing Via Broncograveyard.com is $200. I would do A LOT of research on the 351M swap before going that route.
IMO - an extra $200-300 to swap in a 460 would be much more beneficial than doing the mod. engine swap.
Page generated in 0.38672 seconds with 51 queries
