need some drivetrain parts for my yj - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 3rd, 2006, 10:53 AM   #1
transamsam
lucky #13
transamsam's Avatar
Default need some drivetrain parts for my yj
need stock front diff ring and pinion and stock rear drive shaft for a 1992 yj guy i bought it from blew the front ring and pinion gears so i need the front ones and also need a rear drive shaft he didn't know it was missing. let me know what you have i really need these parts let me know.
thanks sam
transamsam is offline   Reply With Quote
Old August 3rd, 2006, 11:20 AM   #2
PavementPounder
PavementPounder's Avatar
We would really need to know the gear ratio and probably if its stick or auto for the front driveshaft - or its running length.
Old August 3rd, 2006, 11:31 AM   #3
transamsam
lucky #13
transamsam's Avatar
not sure of the gear ratio in the front just stock what ever that is. and is is a 4.0 HO with a 5 speed stick it measures 16 in from the tial shaft to the rear end thats all i know now but i will try to find out a little more on it but if any one has any info on it that would be great let me know.
thanks sam
Old August 3rd, 2006, 11:35 AM   #4
PavementPounder
There's a tag on the differential cover that has the ratio on it. You may need a wire brush to clean it off.
Old August 3rd, 2006, 11:38 AM   #5
Chop
Mischievous Badger
Chop's Avatar
stock in my 92 4.0 5 speed it was a 3.07 gear ratio. i have my 3.07 ring and pinion here. it is still in the front axle i have in my shed. if your want it PM me
Old August 3rd, 2006, 12:22 PM   #6
TJrockdogg
Living on the Edge
TJrockdogg's Avatar
I have a stock ring and pinion for a front XJ 3.55 gear ratio. the only problem is that they are for a HP D44 axle. these are brand new no miles on them, but probably won't work in a stock YJ. but you can let anyone know.
TJrockdogg is offline   Reply With Quote
Old August 3rd, 2006, 12:36 PM   #7
PavementPounder
XJ's don't have D44 fronts. Did you mean HPD30?
Old August 3rd, 2006, 12:43 PM   #8
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
I heard that some xjs made for the foreign market came with hp44s.
Old August 3rd, 2006, 03:23 PM   #9
4X4TJSport
wtf?!
4X4TJSport's Avatar
Send a message via AIM to 4X4TJSport
thanks sam
its more like 16 1/2 - 16 3/4 in from tail shaft to rear end on urs. I was thinking about it and I'm thinking it MIGHT not be ur ring and pinion. We need to take that cover off to see what goin on in there.
4X4TJSport is offline   Reply With Quote
Page generated in 0.28789 seconds with 50 queries
