NP205 shift patern with 3 positions - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 3rd, 2010, 05:40 AM   #1
Judo
Science Patrol
Judo's Avatar
Default NP205 shift patern with 3 positions
I have A GM NP205 transfer case. It is set up with a single shifter on it. The shifter and boot have no markings to indicate how it is engaged. I have looked for shift pattern on line and found most state that it is 4LO-N-2HI-4HI. I'm only feeling 3 separate positions or detentes though. Forward is 4 wheel drive, Center is Neutral and all the way back is 2 wheel only. I do have manually lockng hubs. I guess I am not sure if the linkage is set up wrong or if my transfer case whacked.
Thanks for any help...
Judo is offline   Reply With Quote
Old May 3rd, 2010, 06:03 AM   #2
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
http://www.litegrip.com/shiftpatterns/np205.jpg
Sometimes it will go right through neutral and right into 4H. That's what you might be feeling.
Page generated in 1.19334 seconds with 29 queries
