Jetting, who knows their Sh$t - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 2nd, 2010, 12:10 AM   #1
Mclovin
"The Situation"
Mclovin's Avatar
Default Jetting, who knows their Sh$t
so im putting an 05 honda 450R carb on my 00 honda 400ex (fairly common swap) i have a 12.5:1 440 big bore.. pro circuit T-4 exhaust no air box lid. K&n filter. stg 2 hot cam (thinkin about going to a stage 3) im also running a white bro's CDI box but i dont think that affects jetting. who around here knows jetting ? cause i have NO idea where to start..
I looked on ATV riders and all i got were a bunch of "well i run this jet in my 416 motor or umm make sure you use the 450 fuel line" for some reason no one will come out and says i have a 400 kit with that exh and i run these jets.. and even then their elevation might be way off. The quad is at my buddies house in dearborn where ive been working on it if anyone down there wants to give me some advice on whats jets to order before i buy a bunch of jets i dont need.
Old May 2nd, 2010, 12:27 AM   #2
Bc1980
i was bored saw this hope it helps maybe
good luck with the 40+ pages
http://www.exriders.com/vbb/showthre...0&pagenumber=1
Bc1980 is offline   Reply With Quote
Old May 2nd, 2010, 12:31 AM   #3
Mclovin
"The Situation"
Mclovin's Avatar
yea i looked through that one.. im sure i missed a few details..
i forgot i posted this one a while back
http://www.exriders.com/vbb/showthre...hreadid=432871 i may try his set up a starting point. ive got a while to look around my cylinder is still at the machine shop.
Old May 2nd, 2010, 12:38 AM   #4
Bc1980
Its really going to be a trial and error every single motor is different.yeah somebody elses setup will probably get you close enough .but will be it be dead on your guess is as good as mine.hope it works out for you.
Old May 2nd, 2010, 12:39 AM   #5
Bc1980
do you know what the stock 450 carb has in it?
That guy knows what hes talking about as far as figuring out jetting and tuning
Old May 2nd, 2010, 01:25 AM   #6
Ebs
If you're eyes are watering it's running rich, if you're melting pistons it's running lean. Shoot for somewhere in between.
Check out thumpertalk too, I'm pretty sure they have a motorized sofa section (ATV).
Old May 2nd, 2010, 10:58 AM   #7
Mclovin
"The Situation"
Mclovin's Avatar
damn ! who invited this guy ?
Old May 2nd, 2010, 12:27 PM   #8
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I know my shit.
I would start with the stock 450 sizes and buy the next 3 steps leaner / 2 steps richer and get whatever needle is popular with the squids these days.
All of the mods you performed might get you close to flowing as much as a stock 450R and any extra fuel will just help with cooling your intake charge to inhibit knock. (12.5:1 cr on a air-cooler is gonna get hot)
Also, I would highly recommend using 15W-40 Delo 400 for your engine oil - it is going to take a beating without an oil cooler.
Any more q's, shoot me a pm.
@clarkstoncracker
Old May 3rd, 2010, 01:17 PM   #9
kixx007
Certified Ypsilantian
kixx007's Avatar
I can only give you this advice.
Should have left it stock.
kixx007 is offline   Reply With Quote
Old May 9th, 2010, 07:04 PM   #10
Mclovin
"The Situation"
Mclovin's Avatar
well that's no fun.. *ricky bobby voice* I wanna go fast !
Old May 9th, 2010, 07:05 PM   #11
Mclovin
"The Situation"
Mclovin's Avatar
I know my shit.
is that the truck oil ?? Im gonna switch to something this AMS oil is good oil but too damn pricey.. thanks for the help ! i guess ill fire it with the stock jets and see how it runs and what the exhaust and plug look like..
Old May 11th, 2010, 06:45 AM   #12
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Yes - the truck oil.
It still has a high phosphorus content and is awesome for lubrication and break-in. "Gasoline" oils have no phosphorus, as it damages catalytic converters if it is ever burned.
@clarkstoncracker
Old May 11th, 2010, 08:08 AM   #13
warner-racing357
WARNER-RACING
warner-racing357's Avatar
Don't waste your time installing that carb. Go get yourself an FCR off a CRF 450 or an 06 or later TRX. Also I would not advise using amsoil in a 400ex. 400ex engine and trans share the same oil and you have a wet clutch system-I have seen amsoil wipe out more than one 400ex clutch. I used to race 400exs before the 450's came out-trust me. I would run honda HP4 oil with out molly. But before you decide on an oil make sure you read up on your cam because I know some hot cams say to not use synthetic oil with them. Did you install over-sized head studs on that?
warner-racing357 is offline   Reply With Quote
Old May 11th, 2010, 03:43 PM   #14
boggin-machine
boggin-machine's Avatar
15w40 rotella t diesel oil is what i run in the trans and motor on my 450. people swear by it on thumper talk.
Old May 11th, 2010, 03:59 PM   #15
koochman450r
koochman450r's Avatar
they are the stock size head studs. and hot cams says to use non synthetic only for break-in purposes.
you won this battle.
Old May 12th, 2010, 07:57 AM   #16
warner-racing357
WARNER-RACING
If I were you I'd be installing oversized head studs or you will be blowing head gaskets left and right. One of the biggest and most over looked problems with 440's with high compression.
Old May 12th, 2010, 11:39 AM   #17
koochman450r
i agree if he was racing and was beating it every weekend. But just as a recreational ride it should be fine. i had a 426ex with 13.5:1 compression and stock studs and never blew a head gasket. It was my trail and dune bike and i raced my 450. I think he'll be fine for what he's doing with it.
Old May 12th, 2010, 06:28 PM   #18
Mclovin
"The Situation"
Mclovin's Avatar
i bought a jug off atv riders with fresh sleeve and new HD headstuds (bigger threads) that's the whole reasoning for this.. well it's my excuse anyway
Old May 21st, 2010, 09:51 PM   #19
Mclovin
"The Situation"
Mclovin's Avatar
I got a trick up my sleeve for tuning it in..
Page generated in 0.43465 seconds with 80 queries
