anyone - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 29th, 2010, 07:46 PM   #1
eagle-eye
Default anyone
know where to get decently priced engine parts for a 1985 yamaha YZ 80?
idiot left engine without a plug in it and the cylinder rusted thus siezing the crank bearings.
any help is greatly appreciated.
eagle-eye is offline   Reply With Quote
Old April 29th, 2010, 08:32 PM   #2
levy
levy's Avatar
i dont know for sure i've had pretty good luck at cheapcycleparts.com for some older bike parts
levy is offline   Reply With Quote
Old April 29th, 2010, 09:25 PM   #3
L4CX
Out for the Summer!
L4CX's Avatar
There is a Place called Slicks in Mason that has Tons of Old bikes. It's a Snowmobile/Motorcycle Grave yard. I would give them a Call, they really know their stuff.
There is also a Place in Mt Pleasant that is similar but even larger. Just north Of Meijer on Mission.
L4CX is offline   Reply With Quote
Old April 29th, 2010, 09:41 PM   #4
90Notch306
90Notch306's Avatar
Check ebay first then call eastern michigan motorcycle salvage. They are in yale, mi. 810-387-3513
90Notch306 is offline   Reply With Quote
Old April 29th, 2010, 10:19 PM   #5
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
http://cgi.ebay.com/ebaymotors/Yamah...Q5fAccessories
http://cgi.ebay.com/ebaymotors/Wisec...Q5fAccessories
http://cgi.ebay.com/ebaymotors/YAMAH...Q5fAccessories
http://cgi.ebay.com/ebaymotors/ws/eB...d=360170667966
Get busy.
@clarkstoncracker
Old April 29th, 2010, 10:20 PM   #6
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
BTW, I'm not too far away if you need help.
@clarkstoncracker
Old April 30th, 2010, 01:53 PM   #7
eagle-eye
from what i have seen, i need a new kick/idler gear, new crank bearings, piston, cylinder bored, rings, reeds, reed block and carb.
i will post pics of under the clutch case revealing what i found minus springs and clutch plates.
Old April 30th, 2010, 03:10 PM   #8
Tizken
Ive had bad luck with slicks, but it was years ago. Way to much $$$$ for everything.
Tizken is offline   Reply With Quote
Old May 1st, 2010, 09:06 AM   #9
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
You get to this point, you should rethink repair and start looking for another bike.
@clarkstoncracker
Old May 6th, 2010, 02:15 PM   #10
eagle-eye
how do i remove the magneto on the left side of the engine???
Old May 7th, 2010, 01:10 PM   #11
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
You need a flywheel puller to thread in to the inside of the mag (flywheel) and press against the end of the crank to pop it off.
@clarkstoncracker
Old May 8th, 2010, 10:06 PM   #12
eagle-eye
kinda like a harmonic balancer puller? if so, there is nothing on the flywheel to thread into. just a keyway, and multiple phillips head screws around the outside.
Page generated in 0.26407 seconds with 59 queries
