Odd Problem?! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 28th, 2010, 11:06 PM   #1
OldManGrand
Default Odd Problem?!
Hey everyone been away for a little while sold the jeep but just picked up a dakota. great truck for what i paid but has one wierd problem. the defrost is always blowing warm air. no matter what position i put the controls in including off or even moving it to cold, there is always warm air coming out the defrost. i checked all the vacuum lines, everything seems normal. anyone have any insight? or maybe a vacuum diagram to make sure i'm not missing everything.
OldManGrand is offline   Reply With Quote
Old April 28th, 2010, 11:24 PM   #2
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Check whatever linkage/actuator controls your blend door. It sound like the door is stuck open. If you have cable operated controls maybe the cable is broken or has come disconnected. If you have electric controls then look at the switch in the dash or the blend door motor under the dash. If the heater core has ever leaked there is a good chance the motor down by the passengers feet got wet and ceases to function.
Old April 29th, 2010, 10:29 PM   #3
OldManGrand
checked the blend door, its operating, but all the other controls dont work. the fuses are all ok.
Page generated in 0.19138 seconds with 32 queries
