HORN PROBLEM left turn honking issue 2003 silverado - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 28th, 2010, 03:55 PM   #1
srlbotanical
Because I Said So...
srlbotanical's Avatar
Default HORN PROBLEM left turn honking issue 2003 silverado
My dad has an 03 with a horn issue.
He was out of town about two weeks ago. At 1AM the horn goes off, a steady honk, and continues for 45 minutes until the horn burns out.
He takes it to the dealer, they can't find anything, and just replace his horns.
Today he calls me because the truck is now honking occasionally when he turns left.
I did a couple searches on Chebby sites. I can find this same issue in a few other threads. Some say it's a "warped plate" in the steering wheel, others have fixed it by replacing the multi-function turn signal unit.
Anybody seen this before?
Any help would be much appreciated.
Thanks!
Steve
srlbotanical is offline   Reply With Quote
Old April 28th, 2010, 03:59 PM   #2
Bc1980
yep have seen this has the steering wheel been apart?
possible horn contact in the steering column
Bc1980 is offline   Reply With Quote
Old April 28th, 2010, 04:32 PM   #3
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
I've seen it. It's the clock spring contact in the steering wheel. It keeps continuity in the switch so the horn will still honk when the wheel is turned. If that is bent, the contact will hit that ring when turning.
Old April 28th, 2010, 04:36 PM   #4
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
I have heard of it but it was always a prank that people would play by hooking the horn to the turn signal wires.
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Old April 28th, 2010, 04:37 PM   #5
Bc1980
yeah what he said. x2
Old April 29th, 2010, 08:46 AM   #6
srlbotanical
That makes sence for the turning honk. Any idea why it would go off in the middle of the night?
Also, is it safe to pull the steering wheel apart (airbag) if I just disconect the Neg battary terminal?
Thanks.
Old April 29th, 2010, 09:01 AM   #7
Red68Camaro
End nerd persecution
Red68Camaro's Avatar
Thanks.
It's a good idea to pull the negative cable just to be safe. Just make sure when you re-install the airbag you should hear hear two audible clicks (I think there are two pins one on each side on that bag). Just make sure it is fully seated into the wheel. Last thing you want is that module flying out of the wheel into your face. I've seen it happen!
Red68Camaro is offline   Reply With Quote
Old April 29th, 2010, 09:17 AM   #8
GreaseMonkey
Pew pew!
Thanks.
Wait at least 5-10 minutes after disconnecting the battery before removing the air bag. Most air bag systems have a capacitor to still set the bag off if battery power is lost.
The clearance between the contacts is very small to begin with. If that ring is warped, the temperature change between day and night could be just enough to get it to go off. I'm assuming it was just a constant sound?
It could still be something else but the turning thing kind of pinpoints that contact ring. I would have him check if having the turn signal on or off makes any difference, just to make sure the multi-function stick isn't yanking on a wire or anything like that.
Old April 29th, 2010, 09:29 AM   #9
Red68Camaro
If you get a chance when you pull that module out take pictures of the steering wheel horn plate assembly and the bottom side of the driver airbag. I'll see if I can see any abnormalities with the horn system. I've designed quite a few steering wheels and driver airbags for GM since that's what I do for a living.
Old April 29th, 2010, 09:50 AM   #10
Flexin' XJ
Flexin' XJ's Avatar
When removing the air bag, remove the negative cable, then also pull the Air bag fuse, and disconnect the yellow air bag connector under the dash or knee bolster panel. You don't want that thing going off.
I would only ever pull the fuse when I pulled the air bag but I should have done all the above.
Flexin' XJ is offline   Reply With Quote
Old April 29th, 2010, 09:53 AM   #11
Red68Camaro
He'll be fine just pulling the fuse and cable. I wouldn't mess with the connector under the knee bolster.
Page generated in 0.35409 seconds with 56 queries
