wheel bearing lock nut - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 2nd, 2006, 06:36 PM   #1
going-strong
'96 360 sport 4x4
going-strong's Avatar
Default wheel bearing lock nut
does anybody know what size the wheel bearing lock nut is on a 1996 ram 1500
any help would be greatly welcomed
going-strong is offline   Reply With Quote
Old August 2nd, 2006, 06:41 PM   #2
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
36 or 37mm I think? Don't quote me on that.
Old August 2nd, 2006, 06:44 PM   #3
PavementPounder
PavementPounder's Avatar
I was thinking 36mm. I know I have a socket for my Ram, but that's a Dana 60.
Old August 2nd, 2006, 06:45 PM   #4
going-strong
'96 360 sport 4x4
is yours a 36mm...i also have a D60
Old August 2nd, 2006, 06:50 PM   #5
PavementPounder
Went outside. The D60 is way bigger than 36mm, so that might be correct for the D44. I couldn't find my D60 socket.
Old August 2nd, 2006, 07:05 PM   #6
going-strong
'96 360 sport 4x4
i have a 1 3/4" and it is a little to big...does something something like a 44mm sound familiar?
Old August 2nd, 2006, 07:30 PM   #7
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
I used an 1 3/4" socket that I turned down on a lathe to work. You could use the bench grinder to do the same thing.
Old August 2nd, 2006, 07:35 PM   #8
going-strong
'96 360 sport 4x4
i dont follow...grind it down?
Old August 2nd, 2006, 10:00 PM   #9
KILLER"B"468
Yankabilly
The socket was to thick to fit into the hub to fully engage on the nut :tonka: So I turned the outside diameter so it would fit.
Old August 3rd, 2006, 10:08 AM   #10
PavementPounder
There isn't a clearance problem like that on a unit bearing Dodge D60. I think he means the inside of the SAE socket is loose on the nut.
Old August 3rd, 2006, 12:04 PM   #11
KILLER"B"468
Yankabilly
There was on the one I had done, it was a 94-95 1500 i believe. Definitly had hub clearance issues. Maybe they got better in the newer hubs, all I know it was a PITA.
Old August 3rd, 2006, 12:17 PM   #12
PavementPounder
I would assume that the 1500's D44 hub would be smaller and the clearances around the nut would be tighter - especially if it was the same size nut as the D60.
Old August 3rd, 2006, 02:20 PM   #13
going-strong
'96 360 sport 4x4
correct
Old August 3rd, 2006, 03:30 PM   #14
noodles
give 'er sh*t ay?
noodles's Avatar
i had to turn my socket down so it would ingage the nut fully also.
Old August 3rd, 2006, 05:00 PM   #15
PavementPounder
And what size/axle was that?
Old August 3rd, 2006, 07:21 PM   #16
Spence1986
SlowBalt SS
Spence1986's Avatar
Send a message via AIM to Spence1986
The socket for the nut on my truck was 1 11/16" one inch drive.
Spence1986 is offline   Reply With Quote
Old August 3rd, 2006, 07:32 PM   #17
GreaseMonkey
Pew pew!
When I did my front axle u-joints (D44 front) on my truck, I can't remember what size nut I used but I didn't have to turn the outside of it or anything like that to pull the hub off.
Old August 3rd, 2006, 07:35 PM   #18
going-strong
'96 360 sport 4x4
d60 front?
Old August 3rd, 2006, 10:50 PM   #19
PavementPounder
Good thing you didn't. If you turned the outside of the nut, it would be pretty hard to get off, Mr. ASE.
d60 front?
96DodgeCTD :miff:
(Yes. Have also seen his truck.)
Old August 4th, 2006, 06:29 AM   #20
GreaseMonkey
Pew pew!
96DodgeCTD :miff:
Done yet?
Page generated in 0.40515 seconds with 83 queries
