WTT/WTS 2007 Mid Engine Buggy(Atlas, Red's, V8, Spider 9's) for Muscle Car - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 25th, 2010, 10:21 PM   #1
LockedLJ
LockedLJ's Avatar
Default WTT/WTS 2007 Mid Engine Buggy(Atlas, Red's, V8, Spider 9's) for Muscle Car
Here's the basics on the buggy.
111" wb, 19-20" belly, 47" at A pillar, 53" at B pillar..
Engine:
95' 5.0l 302 ford m.p.f.i
Ford Racing (TURN KEY) Racing harness
Griffin Radiator with aluminum catch can
Stefs racing custom oil pan (traps and baffling)
Milodon high flow water pump w/high flow thermostat
Taylor Spark Plug wires
Custom exhaust
12 gallon rci cell ( for those longer trips!)
Transmission:
Ford C6 automatic
Lokar shifter
Lokar tranny dipstick
Amsoil Synthetic Fluid
Perma Cool tranny cooler with elec. fan
Transfer Case:
Atlas II 4.3 1350/1350 Heavy Duty yokes
Front Axle:
Spidertrax spider 9 front with Chevy kingpin inner and outer knuckles. CTM u joints, 4340 chromoly inner and outer shafts, 5.43 gears w/ spool. Heavy duty 1350 forged yoke.
Blasin Motorsports custom machined axle shafts - clearanced for over 45 degrees of steering (currently running about 42 degrees)
Steering:
PSC 1200x pump with PSC reservoir. Perma Cooler with electric fan.Poison Spyder High Steer arms. Industrial double ended ram with aeroquip fitting and line used throughout.
Rear Axle:
Spider 9 rear with Spidertrax Offroad ultimate end cup kit. Full floater axles, complete with Spidertrax 4340 chromoly axle shafts. Braking power provided by Spidertrax 14' cross drilled rotors and Wilwood caliper set up. Complete Strange 3rd member with spool and 5.43's. Heavy duty forged 1350 yoke
CNC cutting brakes
Wilwood Dual Master Cylinders
Suspension:
Front is triangulated 4 link using FK bearing and QA1 rod ends. 16" SAW 2.0" airs and Light Racing 3" Jounce shocks. 36" limiting straps
Rear is a reverse triangulated four link set up that also uses FK bearing and QA1 rod ends. 16" SAW 2.0" shocks along with 3" Light Racing Jounce shocks. 36" Limiting straps
Wheels/Tires
39" Red Label Krawlers with 65-70% tread left mounted on black powdercoated Walkers.
Recovery:
Warn 9.0 RC w/ 85' of 5/16" rope
Safety:
(2) HA1 2.5lb fire extinguisher
Misc:
12vguy switchpanel and Winch Controller, Autometer gauges, etc.
PRP Roadsters, Crow Harnesses
Spare ujoints,steering and suspension heims, 9" yoke, front driveshaft, unit bearing, 39" blue label on stl wheel
VisonX LED headlights and Tantrum rock light kit installed - also have 2 red tantrum lights wired up as taillights.
I have enough 1/2" black UHMW to skin the boatsides and belly, not installed but will be sold with the buggy.
Gt40p intake,tb and mass air - will require exhaust rework to fit though.
Pic from the original owner
Scaled out..
Sittin a little high, but similar to how I run it for rock hoppin
Got Steering?
Blurry Cell pic of the updated office
Buggy pics here
http://good-times.webshots.com/album/563907384WOuMGD
or you can goto my webshots root directory - plenty of wheelin shots there...
Looking for $24,500 obo.
Would consider muscle car/hot rod in trade(no junk) - up or down...Specifically interested in 55 Chevy, 62-67 Chevy II, 67-72 Camaro, 68-72 Chevelle, 03-04 SVT Cobra, but let me know what you have, ya never know...
And yes, its in TX, but have plenty of family and friends still in MI, so if the deal is right I am sure we can work something out...
LockedLJ is offline   Reply With Quote
Old April 28th, 2010, 07:16 PM   #2
LockedLJ
LockedLJ's Avatar
Bump
Page generated in 0.29136 seconds with 29 queries
