School me on transmissions (4r44e) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 25th, 2010, 01:00 AM   #1
trogdor the burninator
Insert Comment Here.
trogdor the burninator's Avatar
Send a message via AIM to trogdor the burninator Send a message via MSN to trogdor the burninator
Default School me on transmissions (4r44e)
well, i just installed what looks to be a very recently rebuilt 1995 4r44e. i would guess it has under 10k on it..anyway, so i filled it up with 8q 2.5pints and started her up. I am getting a good clean shift into reverse. more rpms are needed to put it into first, second and drive..
I did not reconnect the speed sensor yet due to it being a complete piece of junk. but will tomorrow to see if that would have any effect on the problem...While it is running it has always been in limp mode (flashing od off) and not shifting out of first gear.
how can i fix this crap so i can get out to wheel!?
thanks
Just another disgruntled OIF vet.
trogdor the burninator is offline   Reply With Quote
Old April 25th, 2010, 01:09 AM   #2
Shotgun
I only wheel with boats.
Shotgun's Avatar
ummm............ since you own it and with your track history it will die soon.
Old April 25th, 2010, 01:06 PM   #3
insaneoffroader
insaneoffroader's Avatar
If it is anything like the fullsizes of that era you need the speed sensor hooked up. If its junk replace it.
If parts ain't flyin' you ain't tryin'
insaneoffroader is offline   Reply With Quote
Old April 25th, 2010, 02:25 PM   #4
is why wheeling is expensive
Old April 25th, 2010, 02:30 PM   #5
94rangeron35s
bought a Jeep
94rangeron35s's Avatar
this is very true. you need the vss (vehicle speed sensor) for the trans to shift properly.
Page generated in 1.13658 seconds with 38 queries
