How long to swap out glowplugs on a 7.3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 23rd, 2010, 09:18 AM   #1
clarkstoncracker
lol
clarkstoncracker's Avatar
Default How long to swap out glowplugs on a 7.3
1999 f450, all the glow plugs. How much time should I plan on using up for this task?
It's in the shop and I'm being quoted at $680 for the labor + parts. I can get the plugs for $8.00 a piece from my local napa.
Old April 23rd, 2010, 09:34 AM   #2
Tom
Because racecar
Tom's Avatar
It is not fun when they snap off in the head .
Edit*
Are you going to attempt this yourself? I would say 1-2 hours per side.
Old April 23rd, 2010, 09:40 AM   #3
s.hembree
s.hembree's Avatar
Depending on which shop guide, it books for 3.5-4.2 hours.
Old April 23rd, 2010, 09:41 AM   #4
clarkstoncracker
lol
thanks guys. Are there anything under the valve cover I need to worry about, such as harnesses or the like? I just need plugs, and valve cover gaskets?
Old April 23rd, 2010, 09:59 AM   #5
s.hembree
s.hembree's Avatar
If I recall correctly you shouldn't need anything except plugs and gaskets unless the harnesses are in poor condition... won't know until you get it apart.
Old April 23rd, 2010, 10:05 AM   #6
Tom
Because racecar
Tom's Avatar
Take a good look at the valve cover gaskets. They have a plug that goes through them for the harness that goes to the injectors & glow plugs, they like to burn up.
Old April 23rd, 2010, 10:13 AM   #7
s.hembree
s.hembree's Avatar
What glow plugs are you getting from Napa for $8? From what little bit of experience I have and the "word on the street" I think it would be worth the couple extra bucks apiece to get some Motorcrafts.
Old April 23rd, 2010, 10:17 AM   #8
clarkstoncracker
lol
Autolite's are $8 Champions are $14
hell, even if 1/2 of them work, I'll be happy
Old April 23rd, 2010, 10:20 AM   #9
s.hembree
s.hembree's Avatar
Haha nice... not sure how well you buy parts, but Motorcrafts are only $11 from my supplier.
Old April 23rd, 2010, 03:20 PM   #10
frdboy
frdboy's Avatar
X2!
Also go to your Dealer and buy 1 package of 2C3Z-14A163-AB
That is a small retainer that keeps the harness on the inside of the V/C from vibrating loose.
Labor wise it's about 2-4 hrs total.
Old April 24th, 2010, 05:41 PM   #11
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
A couple of tips:
If the plug doesn't come out, or gets tough to turn, don't force it. Try running it back in a bit, then back out - sorta like when you're cutting new threads with a tap. Take your time.
Use a mightyvac or something similar to evacuate the oil out of the glowplug recesses before you pull them out. Oil = fuel and you can get a rather unsavory start-up if you have cylinders with a bunch of oil in them.
Enjoy removing the I/C plumbing.
@clarkstoncracker
Old April 24th, 2010, 06:34 PM   #12
Bones
Bones's Avatar
you will be pissed when your cheap glow plugs snap off in the cylinder and wreck the cylinder lining.
Get the motorcrafts
You don't need valvecover gaskets, they are reusable.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old April 24th, 2010, 07:59 PM   #13
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
X10 on the autolights being junk, Beru is who makes the motorcraft plugs. Best you can get for a ford. On the IDI motors the autolights swell up and break off when you try and remove them
Old April 24th, 2010, 08:52 PM   #14
MilwaukeeF350
Dan
If I were you I stick to motorcraft.
Autolite's tip will get swell then stuck inside.
Old April 25th, 2010, 09:55 PM   #15
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I've seen this happen to dogs before.
@clarkstoncracker
Old April 25th, 2010, 10:04 PM   #16
lastmanstandin
EvL 1
lastmanstandin's Avatar
Send a message via Yahoo to lastmanstandin
Happened to me once...
lastmanstandin is offline   Reply With Quote
Old May 28th, 2010, 09:31 PM   #17
chrsnrwd
chrsnrwd's Avatar
If they are all inoperative you might want to check the relay. Also the harness is part if the gasket.
chrsnrwd is offline   Reply With Quote
Page generated in 0.40122 seconds with 74 queries
