WTB 87-95 chevy 350 carb intake manifold - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 21st, 2010, 05:04 PM   #1
jeepyj93
Sundowner
jeepyj93's Avatar
Exclamation WTB 87-95 chevy 350 carb intake manifold
I am looking for an 87-95 Chevy 350 intake manifold for a 4 bbl carburetor. New or used. Let me know what you have.
jeepyj93 is offline   Reply With Quote
Old April 21st, 2010, 05:19 PM   #2
davidkassie
davidkassie's Avatar
why not use the older one with some tapered washers, i can't remember who sells them, check around, mr gasket or someone, may have to grind out the center holes too, but will work if need be
davidkassie is offline   Reply With Quote
Old April 25th, 2010, 03:03 PM   #3
jeepyj93
Sundowner
jeepyj93's Avatar
Anybody have one laying around? Or have a set of the adapter spacers laying around?
Old April 25th, 2010, 03:54 PM   #4
Michigan ZJ
I've got an Edelbrock Performer with like 1,000 miles on it. The center holes were cut for the bolts to go into the 94 heads-never leaked. You can have it for $40.00, I'll be heading to the dunes May 7-9 and can bring it with me. Otherwise, you pay shipping.
Michigan ZJ is offline   Reply With Quote
Old April 25th, 2010, 04:24 PM   #5
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
you can use the old ones easy enough. I always just drilled the base of the bolt hole a bit larger and used an old rocker arm ball on the bolt head. seats tight and doesn't leak
Yetti
Old April 25th, 2010, 04:30 PM   #6
toyota h8r
toyota h8r's Avatar
i use pre86 intakes on post86 but drilling the holes to 72* degrees and made four washers out of spacers and a bench grinder.
nice not having to spend money for "special" centerbolt head intakes
toyota h8r is offline   Reply With Quote
Old May 1st, 2010, 11:09 AM   #7
jeepyj93
Sundowner
jeepyj93's Avatar
Anyone have an sbc 87-95 manifold that they want to sell? Or does anyone have a CHEAP pre 86 manifold that is local?
Old May 1st, 2010, 08:54 PM   #8
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
i have one. $60
Page generated in 0.29434 seconds with 47 queries
