Tube notching - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 21st, 2010, 02:37 PM   #1
Irishjeeper
Irishjeeper's Avatar
Default Tube notching
I'm a rookie at all this cage building. Can I notch tubing w/o a tube notcher? if so, how? If not, where dyou find them? I have a grinder, metal cutter, welder, and air equipment. Let me know.
I'm not building a whole cage just adding to my existing cage.
Thank you,
Nick
Irishjeeper is offline   Reply With Quote
Old April 21st, 2010, 02:39 PM   #2
Pokerob
hug life
Pokerob's Avatar
plasma cutter + grinder.
chop saw + grinder
Old April 21st, 2010, 02:39 PM   #3
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Try da google, it took me 10 seconds.
Old April 21st, 2010, 02:41 PM   #4
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
chop saw notching:
Chop saw notching 101 (With pictures) - Pirate4x4.Com Bulletin Board
using a printed template:
http://metalgeek.com/static/cope.pcgi
chinese tools lovers method:
http://www.harborfreight.com/cpi/cta...emnumber=42324
just spend the damn money and it'll last a long time notcher:
http://www.jd2.com/shop/custom.aspx?recid=3
I'm too good for toilet paper tube notcher tool:
http://www.pipemastertools.com/viewall.html
JohnnyJ is online now   Reply With Quote
Old April 21st, 2010, 02:59 PM   #5
95geo
newbie
95geo's Avatar
I use a pipe master for the tricky ones, band saw and marker for most others and the mill with a roughing cutter for the perfect fit and repeat joints.
I dont own a "notcher" and I dont plan to get one.
Old April 21st, 2010, 03:12 PM   #6
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Well obvioulsy, you have other tools that make having a notcher uncessary like an mill with cutter that's many times more expensive than a notcher.
That's like saying I won't buy a hack saw, I'd rather use either my portaband, horizonal bandsaw, vertical bandsaw, or my shark with a laser strapped to its head.
Old April 21st, 2010, 03:46 PM   #7
95geo
newbie
95geo's Avatar
True, but I use a $200 4x6 horizontal/vertical band saw 10x more than any other tool for notching combined.
During my buggy build so far I've probably done 14 notches on the mill and 8 of those were the 90 degree uprights from the rocker to the belt line. I used the pipe master 4 times so far and every other notch has been with the band saw.
Even without the mill I wouldnt buy a notcher.
Old April 21st, 2010, 03:55 PM   #8
koochman450r
koochman450r's Avatar
i got a harbor freight notcher for christmas and so far it works really good. i just need better hole saws.
you won this battle.
Old April 21st, 2010, 07:26 PM   #9
Yota Bill
slow your drill speed down...alot...and use cutting oil, atf if your cheap about it or cant find a decent cutting oil
I have one as well, and after a few modifications it works decent...it was not alinged very well when I first got it (ok, the alignment was not worth a shit at all) so I fixed taht, then welded a piece of angle where the tube gets clamped into for a better hold on the tube, and to get it actually centered, and then it worked decent...there is still too much slop in the bushing to get a good clean cut, but its close and works just fine
I usually use the chopsaw or band saw though, and then finish it with a grinder...not that I do alot with tubeing though
Old April 21st, 2010, 08:16 PM   #10
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
x2. No problems with mine. Just take it slow.
RDK_YJ88 is online now   Reply With Quote
Old April 22nd, 2010, 03:08 AM   #11
two_much_talk
sit down shut up and ...
two_much_talk's Avatar
yup we used a HF notcher for the cage in my XJ. with a little tweeking it worked great.
Old April 22nd, 2010, 05:22 PM   #12
Irishjeeper
Thanks for the feedback. I think I'll use my Dremel. No not really.
Old April 22nd, 2010, 09:45 PM   #13
Blue XJ
The Green Machine
Blue XJ's Avatar
Send a message via AIM to Blue XJ
x2
I use these and my 4.5" angle grinder and get perfect fits on the notches. Rough cut with cutoff disk, then clean it up with a flap disk, I have 2 grinders, so I don't have to keep switches wheels.
Blue XJ is offline   Reply With Quote
Old April 23rd, 2010, 04:12 PM   #14
Koobklatawa
Yes. What kind of "metal cutter" do you have - gas torch, plasma, sawzall?
Are you replacing tubes or just adding new ones?
Koobklatawa is offline   Reply With Quote
Old April 26th, 2010, 03:44 PM   #15
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Bandsaw + 4.5" grinder, unless you have alot of them to do.
RIP FULLSIZE4LIFE
Old April 26th, 2010, 04:02 PM   #16
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I used a horizontal band saw, the pipmaster tool, hand grinder, and a carbide burr.
Band saw to take majority of the material out, than hand grinder do do clean up, than carbide burr to get a nice smooth finish.
Old April 26th, 2010, 04:35 PM   #17
Koobklatawa
Irishjeeper - Cutting the notch on one end is only part of the problem. As you know, when you add a tube to your existing cage, you must fit both ends. To do this you need to know 3 things: the shape of each end cut, the orientation of the end cuts to each other (won't fit if you twist your cuts even just a couple degrees), and the exact overall length of the tube. If the tube fits well its easy to weld. What I am trying to say is that knowing WHERE to cut is (IMO) more important than HOW you cut it.
Old April 26th, 2010, 10:36 PM   #18
RZG90
RZG90's Avatar
chop saw notching:
better yet im to good for toilet paper notcher
http://www.oceanmachinery.com/jancy-...%20%281%29.htm
RZG90 is offline   Reply With Quote
Page generated in 0.51282 seconds with 78 queries
