*SOLD*FS 78-79 F250 Dana 44 8 LUG HP & DANA 60 -w- 5.13s....$500 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 15th, 2010, 11:06 PM   #1
hillbillyrockstar
Country folks living LOUD
hillbillyrockstar's Avatar
Location: from St. Clair County, working in Baltimore MD for a while
Default *SOLD*FS 78-79 F250 Dana 44 8 LUG HP & DANA 60 -w- 5.13s....$500
Like the title says....I am selling a set of axles from a 78-79 F250. These axles were pulled from a truck about 5 or 6 months ago and worked beautifully when they were removed. The brakes look good and the lockouts work great. The balljoints are tight as well. I was going to use these in the Ranger, but I found a Dana 60 front and a Sterling Rear at the last minute. I was going to hold onto them, but the space needs to be cleared out.
Front is a High pinion Dana 44 with 5.13 gears, complete, hub to hub.
Rear is a Low pinion Dana 60 with 5.13 gears, complete drum to drum. It has 2 brackets for traction bars that were welded attached to it from a previous owner. I can torch these off and grind the tubes smooth if you like.
I also have a steering arm with the raised end for hooking up to the drag link, as well as a spacer block, all for the drivers side knuckle of the Dana 44.
Prices....
front and rear axles with steering arm supplies - $500
front axle without the chromoly shafts - $350
rear axle - $250
Steering arm supplies - $50
I am serious about getting rid of these, and am willing to be very reasonable on any offers I may receive. These would make excellent axles for someone who is looking to do a crawler setup on their rig. Throw a locker, chromos and some bling bling U Joints in the frontend and you are pretty much bulletproof!
Call 810 531 8988 anytime if interested and ask for ZACH. Or PM me. I try to check this a couple times a day and I can get some pics up if someone would like. I can deliver up to 2.5 hours away if needed for the right price. The more stuff you want, amd the more you pay, the further I can deliver!
ALSO.......If you happen to have a manual shift BW 1354 TCase for a Ranger, I may be interested in working that into some sort of a trade deal.
hillbillyrockstar is offline
Old April 18th, 2010, 10:14 PM   #2
hillbillyrockstar
Updated the list and sold the chromo shafts to XJay...hope you enjoy em man!
Old April 19th, 2010, 04:54 AM   #3
IDIeselman
IDIeselman's Avatar
The reason for no return PM. XJay You bastard, I hope you break them the first time out!
IDIeselman is offline
Old April 20th, 2010, 07:03 AM   #4
hillbillyrockstar
BTT.....Going to Flint today and can deliver these if neccessary so I'll be taking them with me.
Old April 22nd, 2010, 01:48 AM   #5
hillbillyrockstar
Sold the axles to Thrill20. Thanks for the quick sale man!
Page generated in 0.21058 seconds with 38 queries
