Ford 9 inch - and a Dana 44 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 13th, 2010, 03:04 PM   #1
Jeremy B.
<a href="http://my.flight
Jeremy B.'s Avatar
Default Ford 9 inch - and a Dana 44
Ok i got a deal on a Ford 9 inch and a dana 44 i have a 01 XJ with a dana 30 in the front and a chrysler 8.5 in the back what are some of the major issues I will be running into. Also are these axels worth upgrading to?
Jeremy B. is offline   Reply With Quote
Old April 13th, 2010, 03:16 PM   #2
xj4life
xj4life's Avatar
Getting a D44 under the front of your XJ is going to be the biggest "issue". Good and what every one at your point should start with. Read that over and then come back with more questions.
http://www.naxja.org/forum/showthrea...t=dana+44+tech
Old April 13th, 2010, 04:19 PM   #3
Unless you are going to drop $1K in alloy shafts and super joints, it's hardly worth the effort to upgrade the front axle.
Old April 14th, 2010, 11:21 AM   #4
You haven't mentioned your tire size (you sig says 33s), and why you want to upgrade.
If you are only staying with 33" MT type radials, I'd just keep the stock axles, and invest in better front shafts and call it good.
Old April 14th, 2010, 04:29 PM   #5
blue thunder
blue thunder's Avatar
read through my build thread
it shows one way of linking the front axle in
project blue thunder - Great Lakes 4x4. The largest offroad forum in the Midwest
blue thunder is offline   Reply With Quote
Old May 3rd, 2010, 01:07 AM   #6
MJ_Silver_1988
MJ_Silver_1988's Avatar
Send a message via AIM to MJ_Silver_1988
i have the dana 44 and 9" and it was very well worth upgrading the front after bending 3 Dana 30s and blowing both u-joints and the diff all in one shot in one of them. Plus if you drive it down the road very much lockouts are extremely nice to stop the front driveshaft from spinning. Then your also getting better brakes cheaper wheel bearings the ability to do highsteer and the list goes on. I say well worth the upgrade. For an easy way to put the front axle check out TNT Customs.
http://tntcustoms.com/front.aspx
MJ_Silver_1988 is offline   Reply With Quote
Old May 3rd, 2010, 06:57 PM   #7
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
Whiterhino is suggesting that it might be better to just upgrade to a D60 before spending all the money on shafts and such to still have an axle that still has a definite weak point.
That being said, I have a built D44, but I got a good deal on it.
However, it truly depends on what the exact setup is going to be, and if you ever plan on going bigger.
*2007 Rubicon
*2006 Duramax
*2005 CRD
Old May 3rd, 2010, 11:39 PM   #8
MJ_Silver_1988
Fair enough
Old September 12th, 2010, 04:35 PM   #9
itchy
itchy's Avatar
I think your response is spot on.
itchy is offline   Reply With Quote
Page generated in 0.28275 seconds with 51 queries
