**found** 74-79 Wagonner Dana 44 Front Axle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 12th, 2010, 07:33 PM   #1
JimNut
JimNut's Avatar
Default **found** 74-79 Wagonner Dana 44 Front Axle
Exactly as the title says. Looking for a front Dana 44 out of a 74-79 Wagoneer (passenger side drop). Flat top knuckles and 3:55 gears would be ideal but not necessary. This axle should have a WMS to WMS distance of about 60.5" and a bolt pattern of 6x5.5.
Let me know what you have.
JimNut is offline
Old April 13th, 2010, 10:12 AM   #2
JimNut
JimNut's Avatar
bump
JimNut is offline
Old April 14th, 2010, 01:34 PM   #3
JimNut
JimNut's Avatar
Anyone??
JimNut is offline
Old April 16th, 2010, 03:54 PM   #4
jeepguy74
jeepguy74's Avatar
pass drop?
imay have one avalible
jeepguy74 is offline
Old April 19th, 2010, 07:52 PM   #5
J Truck Rick
J Truck Rick's Avatar
I have like 4 ALMOST like that.....they are from '79 down Wide track Cherokees or Jtrucks....I think they are 3:54 gear.3:31's were common AFTER '79,but they also changed to driver drop.One is flat top also
J Truck Rick is offline
Old April 20th, 2010, 05:33 AM   #6
orionn
orionn's Avatar
I have a matched set, front and rear, 3.31:1 gears, 6 lug, and a set of flat tops I could let go with the set. I also have the original mag rims that were on them.
Drivers drop though (they are '82 axles if I remember correctly)
let me know.
orionn is offline
Old April 20th, 2010, 07:57 AM   #7
PavementPounder
PavementPounder's Avatar
He's putting this in a CJ with a Dana 300, guys (I've talked to him about this directly prior to the listing being made). He needs the axle he asked for, which is passenger drop.
PavementPounder is offline
Old April 20th, 2010, 08:08 AM   #8
J Truck Rick
Mine ARE pass drop,just a tad bit wider than he wants,they could be narrowed.
I'd let the one with flat tops go for$100 if that helps.
Old April 20th, 2010, 09:44 AM   #9
PavementPounder
I'm not making decisions for him and I don't have a 74-79 FSJ NT to offer him, but I know that he does not want his vehicle to get significantly wider and that he does not want to get into the expense and hassle of narrowing axles. He's already going to have to outboard the front springs. Narrowing a FSJ WT front will put the perch under the framerail, but it will also cause it to not match the rear he's considering.
Old April 20th, 2010, 09:53 AM   #10
orionn
orionn's Avatar
OK, no problem. thx PP.
Drop was not specified,(though implied by the years), so I threw mine out there. :)
I got a D300 flip kit i'd sell
orionn is offline
Old May 2nd, 2010, 08:10 PM   #11
JimNut
JimNut's Avatar
Thanks for the comments PP! Still looking for one if anyone has one!
JimNut is offline
Old July 31st, 2012, 02:15 PM   #12
JimNut
JimNut's Avatar
Back to the top!
JimNut is offline
Old July 31st, 2012, 07:41 PM   #13
gearedfather
Default 44 wag front
we used to use these on cj,s back in the 80,s (yes i,m old) only had to narrow one side and they fit pretty good. (police didn,t see it that way)...i have a few left. probably 3.07 ratio..located in st. paul mn area...612-309-3999
gearedfather is offline
Old July 31st, 2012, 07:50 PM   #14
Little Dave
Little Dave's Avatar
Originally Posted by JimNut View Post
Back to the top!
So two years later and your still looking? I thought my projects were slow.
Little Dave is offline
Old July 31st, 2012, 11:10 PM   #15
JimNut
JimNut's Avatar
Jeep has been driven regularly during the last couple years just wasn't actively looking to upgrade the front axle. Bought a house last year and then decided to swap in a 360 this past winter. Just put 38.5 TSL's on it and figure the Dana 30 won't last long so i should probably start looking again. Haha
JimNut is offline
Old November 4th, 2013, 08:00 PM   #16
JimNut
JimNut's Avatar
3 years and counting now
Putting this back up to the top!
JimNut is offline
Old November 10th, 2013, 08:33 PM   #17
JimNut
JimNut's Avatar
Finally picked up one up today. Just a bare housing but at least it's a start!
JimNut is offline
Page generated in 0.36929 seconds with 74 queries
