gas vs diesel trans - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 12th, 2010, 11:10 AM   #1
jmdzuk
jmdzuk's Avatar
Default gas vs diesel trans
Is a Gas e40d the same as a diesel?
jmdzuk is offline   Reply With Quote
Old April 12th, 2010, 11:18 AM   #2
Tom
Because racecar
Tom's Avatar
no.
*edit
I'll explain what the differences are:
Bell housings
Forward Drum.... Diesels are splined all the way through, and use more clutches
Diesels have more overdrive clutches.
Valve body calibrations.
F450/550 autos have 6 pinion steel planets.
just to name a few.....
Old April 12th, 2010, 03:32 PM   #3
jmdzuk
jmdzuk's Avatar
Originally Posted by Tranny Tom View Post
no.
*edit
Bell housings
This is true for the early 90s as well 460 gas to 7.3 PS
Old April 12th, 2010, 08:38 PM   #4
Tom
Because racecar
Tom's Avatar
is this a question? What are trying to do? Put a 460 e40d behind a 7.3?
460 and the 7.3l have different bell housings.
Old April 12th, 2010, 09:06 PM   #5
jmdzuk
jmdzuk's Avatar
yes, and thank you. I have a 7.3 2 wd and i am collecting parts to make it 4wd maybe.....
Thanks Jeff
Old April 12th, 2010, 09:16 PM   #6
Tom
Because racecar
Tom's Avatar
Thanks Jeff
So, you need to make the 7.3 trans a 4x4? You can use any 4x4 output shaft and tail housing from any E40D, those parts are all the same.
Old April 12th, 2010, 09:46 PM   #7
jmdzuk
jmdzuk's Avatar
Really..
I have a freinds dad that needs a 2wd trans for his 460.We were going to trade,but that wont work .But what you are telling me I can swap parts and keep my good trans.
What all is involved in the swap? do you have to pull the trans completely apart? or is it just the tail end?
Thanks Jeff
Old April 13th, 2010, 06:16 AM   #8
Tom
Because racecar
Tom's Avatar
Really..
Thanks Jeff
Unfortunately yes it has to come apart. Valve body and all.
Old April 17th, 2010, 07:57 PM   #9
jmdzuk
jmdzuk's Avatar
well i bought a complete donar truck. 97 crew cab 4x4 I should be able to swap over everything much easier now:-)
Page generated in 0.23462 seconds with 50 queries
