truck wont start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 11th, 2010, 09:18 PM   #1
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
Send a message via AIM to dakotaguy1
Default truck wont start
im not getting any spark to the coil on my 83 ram and i dont really know what the problem is and dont know what the next step is or what to check next any help would be great! my buddy said maybe bad ignition switch???? but im not sure because it crancks and everything just no power to the coil..
thanks joel
dakotaguy1 is offline   Reply With Quote
Old April 12th, 2010, 07:57 AM   #2
Flat_Black
The Dodge Guy
Flat_Black's Avatar
check the pick up coil, under dist. cap and rotor?
Old April 12th, 2010, 08:12 AM   #3
Wheelman
Extreme Mudder
Wheelman's Avatar
Ignition Control Module on the firewall. Like 20.00 at autozone and would think they could check it for free.
Wheelman is offline   Reply With Quote
Old April 12th, 2010, 08:17 AM   #4
Flat_Black
The Dodge Guy
Flat_Black's Avatar
or the ballast resistor on the firewall also
Old April 12th, 2010, 05:47 PM   #5
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
alright i will check that
Old April 12th, 2010, 11:16 PM   #6
ohiocowboy1277
the master of disaster
a little trouble shooting info for dodges : if it cranks and starts then stalls when you relese the key the ballast resistor is bad if it cranks but wont start at all the most likely culperate is the ignition modual on the fire wall
ohiocowboy1277 is offline   Reply With Quote
Old April 12th, 2010, 11:29 PM   #7
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
thanks ill start with that what causes them to go bad do you know?
Old April 12th, 2010, 11:41 PM   #8
ohiocowboy1277
its a common problem on dodges the modual and the ballast resistor the moduals just tend to break down from heat and age the epoxy on the back of them starts to not seal as well and they corrode inside
Old April 12th, 2010, 11:47 PM   #9
ohiocowboy1277
btw i like to keep a spare of both with me because they seem to fail at the worst possible time atleast for me lol
Old April 12th, 2010, 11:53 PM   #10
ohiocowboy1277
i own 4 dodges right now that have that set up and ive owned others before so i know them well lol the new stuff confuses me but i love my dodges lol
Old April 15th, 2010, 05:22 PM   #11
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
well i went and had the ignition modual tested and it works, put on a new coil and resistor and still wont start what next?
Old April 15th, 2010, 05:29 PM   #12
Flat_Black
The Dodge Guy
Flat_Black's Avatar
did ya check the pick-up coil?
Old April 15th, 2010, 10:04 PM   #13
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
stupid question but wheres that located at
Old April 15th, 2010, 10:09 PM   #14
Freak
Wheelin the HD
Freak's Avatar
inside the distributor.
Old April 15th, 2010, 10:13 PM   #15
Flat_Black
The Dodge Guy
Flat_Black's Avatar
inside the distributor under the cap and rotor, 2 phillips head screws on the out side of the distributor on the sides.
edit heres a diagram for some help just in case
Old April 15th, 2010, 10:25 PM   #16
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
alright thanks will check that next and let ya know
Old May 27th, 2010, 08:30 PM   #17
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
alright worked on it yesterday and today. yesterday it almost started it kinda fired a few times but wouldnt run. so i redid the timing today cause i thought thats what was wrong but not getting spark again. im only getting 4.6v to the coil. we hooked it straight to the battery figuring it would get 12v then but still no spark. didnt try the pick up coil yet. thanks for any help
Page generated in 0.33673 seconds with 74 queries
