dually conversion question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 11th, 2010, 07:35 PM   #1
redneck942
redneck942's Avatar
Default dually conversion question
I have no idea even if this is possible but is there a way where I can convert my 1985 d-150 to dual tires in the rear without putting in a different axle?
redneck942 is offline   Reply With Quote
Old April 11th, 2010, 07:38 PM   #2
somer1
You Get the Big One
somer1's Avatar
Depends on what axle you have, it could be as simple as running dually hub assemblies.
somer1 is offline   Reply With Quote
Old April 11th, 2010, 07:45 PM   #3
redneck942
redneck942's Avatar
it has dana 44 front and rear
Old April 11th, 2010, 07:48 PM   #4
Freak
Wheelin the HD
Freak's Avatar
dually axles are wider front and rear due to the offset on the rims, you might get away with just changing the hubs but will it clear the springs? and I am willing to bet you will have to run non dually rims in the front.
Old April 11th, 2010, 07:54 PM   #5
somer1
You Get the Big One
somer1's Avatar
As far as I know there aren't any dana 44 dually rear ends running around so coming up with a set of hubs with the proper offset to run dually rear wheels using your stock 44 would be a little complicated. If it were me I'd just find a dually 60,70, or even 14 bolt, and change the whole axle. This way you get strength and no real custom parts. My .02
Old April 11th, 2010, 08:09 PM   #6
redneck942
redneck942's Avatar
somer good point, i will have to look into that and see how much a dana 60 and dually hubs would cost i know switching from a 44 to a 60 would be a peice of cake
Old April 11th, 2010, 09:13 PM   #7
Flat_Black
The Dodge Guy
Flat_Black's Avatar
just to help out, d is 2wd and w is 4wd in dodges. the front is a d44 and the rear is a chrysler 9 1/4.
Old April 12th, 2010, 12:57 AM   #8
redneck942
redneck942's Avatar
flat black thank you for clarifying that i appreciate it. i just was told by my brother it was a dana 44
Page generated in 0.20428 seconds with 47 queries
