lincoln 4.6 misfire - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 11th, 2010, 01:49 PM   #1
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
Default lincoln 4.6 misfire
got this 99 lincoln town car that has a random misfire. it will run smooth then miss a few times then run smooth again. scanner said cylinder #4. i put new plugs, and plug boots on it, and recently changed the intake manifold so i cleaned the injectors while it was apart. i'm told that the coil packs go bad often but i've never heard of one working part time. all the coils i've seen go bad stop working completely. so am i looking at a dead coil, or a injector going bad? both are expensive to replace so i'd rather have a good idea before i buy the parts
Old April 11th, 2010, 01:52 PM   #2
Bc1980
swap coil from 4 to somewhere else see if misfire changes to a different cylinder.
ive seen them crack and only misfire when hot
Bc1980 is offline   Reply With Quote
Old April 14th, 2010, 01:53 AM   #3
Blksnshn69
Blksnshn69's Avatar
also possibly a ripped o ring on an injector while you had it apart. It's pretty easy to rip them. Any fuel Leak? Or vacum leak?
Blksnshn69 is offline   Reply With Quote
Old April 14th, 2010, 09:00 PM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
neither. i never bothered with it anymore. owner doesn't have the cash to fix it right now so i'm not putting alot of time into it.
Page generated in 0.22473 seconds with 35 queries
